Thread started 27 May 2009 (Wednesday) 18:07
Multi-focus points
scpictaker
May 27, 2009 18:07 |  #1
Can you select multiple focus points on a 50D? Some shots I take I could use at least one more focus pt. When you use auto select it will sometimes select all pts. however, using auto never gets the one I need so I rarely use auto anyways.
I think this is something Canon should look into if they don't have it yet.
My Flickr (external link)
Canon 5D MKIII l 7D MKII l 24-105L l 16-35 L II l Sigma 50 1.4 ART l 70-200 2.8 L II l 24-70L l EOS M l 2X III l Rok 14mm
beano
May 27, 2009 18:13 |  #2
How can it focus on two points at the same time!?! I think you are looking for a miracle to be honest. ;)
Scott
eosphotomanoftennessee
May 27, 2009 18:23 |  #3
It usually focuses on the closest point and or highest contrast areas of the closest points. That's why they let you select which point to focus upon (user select). I guewss you might want to use live view and let it do face recon if you are doing portraits, otherwise use manual. the camera does have a hard time reading minds and guessing at your desired focus point when you put it on auto select.
Doug, osphotoman@yahoo.com (external link)
7D
;), Canon SX1 IS, Film Rebel for history
300L, 70-200L, 50 1.8, 28-105 EF, Sigma 18-50 EF-S
580Speedlite, AB Ring Flash, Excalibur 320, 2- Morris Optical Slaves
Adobe CS5 Extended, Wacom Graphics Tablet
scpictaker
May 27, 2009 18:30 |  #4
I was taking photos of my wife at a local garden and I would use either a far left or right focus pt. and I really could have used the pt to above or below as well. Maybe I cant explain it well enough. I just dont get why you can't select 2, or 3, or say all pts.
beano
May 27, 2009 18:34 |  #5
scpictaker wrote in post #8000361 (external link)
Because all these points will probably be different distances from the camera. It sounds like you are looking for more depth of field, you get this by making the aperture smaller. I was given a link today for a DOF calculator:
http://www.dofmaster.c​om/dofjs.html (external link)
Scott
scpictaker
May 27, 2009 18:37 |  #6
cool, I'll check it out. Thanks :)
dank ­ ink
May 27, 2009 19:57 |  #7
Yeah I don't see how a lens would be able to focus on different points and distances at the same time.
k.lee
May 27, 2009 20:01 |  #8
How does the camera focus on more than 1 point during auto-focusing then? Like the OP said, sometimes in auto more than 1 point flashes for AF-confirm. What's the AF module doing during something like that?
Kelvin
Gear list
My
Blog
external link / Flickrexternal link
Thalagyrt
D'OH. I need to wake up some more.
May 27, 2009 20:06 |  #9
dank ink wrote in post #8000802 (external link)
Tilt shift lens! Sortakindamaybe. Still one flat focal plane, but you can adjust it.
James
Marcos ­ Dantas
May 27, 2009 20:09 |  #10
Your camera has A-DEEP mode, right? That's will cover it.
The downside is that the camera will choose the focus points for you also.
sorry for my broken english.
Duncan ­ Frenz
Purposely evaded the TF
May 27, 2009 20:09 |  #11
k.lee wrote in post #8000817 (external link)
It is confirming focus at points equidistant from the lens, so all these points will be in focus.
- Duncan
Gear_Mor
e than I need, Less than I want
Nonconformists are all alike.
I am not an expert, but I play one on the internet.:D
dank ­ ink
May 28, 2009 03:27 |  #12
I would think it has to do with the aperture and how much is able to be relatively sharp. If it's a larger aperture and multiple AF lights flashing, I would think it's various points that are on the same focal plane/distance. That's just how I see it, I could be wrong though.
apersson850
Gallery: 11 photos
May 28, 2009 06:11 as a reply to  @ dank ink's post |  #13
Yes, you are. Focusing is always done with the lens wide open. It's like said above, if more then one light up, then they all happen to be within focus.
A 50D can only use all (the camera pics the point/points to use) or one (manual selection). When the camera makes the choice, it will normally use the point(s) that see parts of the subject closest to you and where it finds anything to focus on.
The more advanced cameras (like 1D Mark III) allows you to expand focus to the neighboring points, but still not using all points. This can be useful if you are tracking something flying by, using Servo AF, at higher speeds. Keeping one certain point on the target may be difficult, and having them all enabled may confuse the camera into focusing on something un-related to what you are trying to catch on picture.
Anders
René ­ Damkot
May 29, 2009 10:09 |  #14
A-Dep might do what you want. But IMO it sucks. DEP (external link) was way better.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
apersson850
Gallery: 11 photos
May 29, 2009 11:41 as a reply to  @ René Damkot's post |  #15
I don't understand why they can't make that DEP mode to work like it used to do? With my EOS camera for film, it's like A-DEP if I set the camera to select the focus points automatically, but like DEP if I select a point manually. It would only take that you could select the autofocus points in A-DEP mode to make that possible.
Anders
2,357 views & 0 likes for this thread
Multi-focus points
Latest registered member is Lian van den Heever
902 guests, 301 members online
