I know some people may already know this, but you can cover the back four pins and only have the front pin connected on the hotshoe and you can fire any of your studio strobes and speed lights!
ashdavid Osteoglossum bicirrhosum 986 posts Joined Aug 2006 Location: Japan More info | May 28, 2009 20:26 | #1 I know some people may already know this, but you can cover the back four pins and only have the front pin connected on the hotshoe and you can fire any of your studio strobes and speed lights! 1Ds MKIII, 5D, 30D, EF 50mm f/1.2L , EF 85mm f/1.2L , EF 24-70mm f/2.8L , EF 80-200mm f2.8L, EF 70-200mm f/2.8L IS , EF 300mm f/2.8L , EF 400mm f2.8L IS, EF 800mm f5.6L IS EF 180mm f/3.5L Macro , EF 100mm f/2.8 Macro ..... Speedlite 580EX II x 4, Speedlite 430EX x 1, ST-E2 , Remote Switch,
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | May 28, 2009 23:35 | #2 How does ST-e2 trigger your studio strobes. I thought st-e2 was infrared. COuld be wrong as I haven't used it. Fuji XT-1, 18-55mm
apersson850 Obviously it's a good thing More info | If you have optical slave triggers on your slave flashes, then... Anders
May 29, 2009 03:32 | #4 bobbyz wrote in post #8008981 How does ST-e2 trigger your studio strobes. I thought st-e2 was infrared. COuld be wrong as I haven't used it. What apersson850 said!!! 1Ds MKIII, 5D, 30D, EF 50mm f/1.2L , EF 85mm f/1.2L , EF 24-70mm f/2.8L , EF 80-200mm f2.8L, EF 70-200mm f/2.8L IS , EF 300mm f/2.8L , EF 400mm f2.8L IS, EF 800mm f5.6L IS EF 180mm f/3.5L Macro , EF 100mm f/2.8 Macro ..... Speedlite 580EX II x 4, Speedlite 430EX x 1, ST-E2 , Remote Switch,
| Latest registered member is Sandro Bisotti 1765 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
