Thread started 29 May 2009 (Friday) 22:27
Sigma 100-300 f/4 IF EX HS or Sigma 150-500 OS
Ariel
May 29, 2009 22:27 |  #1
I have a dilemma, I am looking to buy a zoom/telephoto lens and have been looking up these 2 lenses, right now I dont think I need a 500mm reach, so it will be a bonus and I think I can manage without the OS, but it will be a bonus as well, the lens will be mostly used for local airplane spotting and airshows. I have been looking at the Sigma 100-300mm f/4 EX HSM + 1.4x TCon or a Sigma 150-500mm f/4.5-6.3 OS. I have not used any of them, but I do own a 100-400L, so this lens will be for a 2nd body for my wife to use. Anyone has any experience with either one? How comparable will any of them be to the 100-400L? What will be a better option?
Thanks,
Ariel
Feedbackhttps://photography-on-the.net …rch.php?searchi​d=10868450
Tony-S
May 29, 2009 22:46 |  #2
I have both. I can't tell you how they compare to the 100-400L, but:
100-300 f/4 is optically superior to the 150-500 and takes a 1.4x TC very well. I use mine more for sports than anything.
150-500 gives you longer reach and OS and takes a 1.4x TC pretty well. I use this one principally for wildlife.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
Ariel
May 29, 2009 22:54 |  #3
Any significant loss of IQ for both using the 1.4x TC? I know there is always loss, unavoidable, but in which one is more noticeable?
Tony-S
May 29, 2009 22:57 |  #4
I have no hesitation using the 1.4x on the 100-300. The 150-500 isn't bad, though. If you search the 150-500 archive for my posts, you'll see the 1.4x, 2x and 3.4x TC on this lens. That should give you an idea how it does.
condyk
Africa's #1 Tour Guide
May 30, 2009 02:10 |  #5
I've owned both, plus two 100-400mm. I've just picked up another 150-500mm for casual zoo style shooting in the UK. In order I'd go 100-300mm 4.0, 150-500mm, 100-400mm, but that is just based on the quality of images I got from each, before adding in any further criteria.
The 150-500mm OS is fairly large and heavy and very noticeable, but so is the 100-300mm. The latter needs a monopod to get the A1 image quality it is capable of unless you are very steady. It takes a 1.4x very well too, as Tony says.
I used mine around 80% like that, which is why I finally sold it for the 100-400mm. That was a disappointment, both copies where, but then the 100-300mm is one of the best zoom you can buy while the 100-400mm is just a long zoom that does most thing pretty well.
The 150-500mm OS is a better all rounder If you take weight and size out of the decision, but if you don't need 500mm, and 420mm with a tcon on the 100-300mm is still long, then go for the 100-300mm. If you need flexibility in a fairly lightweight package and decent IQ then stick the Canon you already have.
Not sure the 150-500mm or 100-300mm are that suited to a woman shooter, but depends on build and strength. They are both heavy to be swinging around chasing planes. I know the 100-400mm is pretty popular for that stuff. A decent tripod and ballhead or gimbal will sort things.
https://photography-on-the.net …/showthread.php​?t=1203740
1,097 views & 0 likes for this thread
Latest registered member is Ezra Praveen
777 guests, 202 members online
