Thread started 31 May 2009 (Sunday) 15:44
Any tricks for a loose lens hood?
C.Steele
May 31, 2009 15:44 |  #1
I have a 17-55 IS with a third party lens hood. Nice hood, sturdy, flocked, etc. Sometimes when shooting the lens hood rotates and if I don't catch it I get part of the hood in the image (corners). I'm not sure if it's the hood or the lens causing the problem. It may be that I need a Canon hood, and if so I'm fine with buying one. I just thought I'd throw it out here first and see if a) These lenses are known for loose hood issues b) There is a way to fix a loose hood c) a Canon hood will definitely solve my issue (before I spend the money to find out it doesn't).
Chris
Sometimes I do get to places just when God's ready to have somebody click the shutter. -Ansel Adams
Portland Wedding Photographers (external link) | Steele Photography (external link)
ed ­ rader
"I am not the final word"
May 31, 2009 15:47 |  #2
C.Steele wrote in post #8023558 (external link)
Chris
my 24-70L hood does the same thing....it has loosened over time. i may replace the hood someday.
ed rader
5D4 x2, 16-35L F4 IS, 24-70L II, 70-200L F4 IS II, 100-400L II, 14L II, sigma 15 FE, sigma 28 f1.4 art, tc 1.4 III, 430exII, gitzo 3542L + markins Q20, gitzo GT 1545T + markins Q3T, gitzo GM4562
brecklundin
May 31, 2009 15:57 |  #3
Chris
Depending on how loose it really is, you could try a couple layers of nail polish or model paint on the "threads" of the hood to snug up the fit. It will wear off over time but can be re-applied as needed.
Something else I have used in similar situations when a thing needed snugging is just plumbers teflon tape. It is the cleanest option but some experimenting is needed to get the right amount of it in there. Nice thing about the teflon tape is you can always carry a roll in your bag to make a fast fix when the tape falls apart eventually. The other nice part of the tape is you can put it on the lens threads easily and it's clean of you want to remove it...
Real men shoot Pentax because we're born with our own Canon's!!
{Ok...ok, some of use just have a PnS but it it always makes me happy! :D}
Pentax K5, K20D, Three Amigos (Pentax FA 31/1.8 Limited Silver, Pentax FA 43/1.9 Limited Silver, Pentax FA 77/1.8 Limited Silver), Pentax DA 35mm F2.8 Macro Limited, Sigma 24-60/2.8
C.Steele
May 31, 2009 16:14 as a reply to  @ brecklundin's post |  #4
Couple of great ideas there. Thanks a bunch Breck!
brecklundin
May 31, 2009 16:33 |  #5
cool...hope they work for ya. :D I swear, next to gaffers & duct tape, plumbers tape is about one of the most handy things around.
Simon ­ Turkin
May 31, 2009 16:35 |  #6
elmers
Gripped 50D - AE-1- Canon 70-300 is usm - Canon 28-135 is usm - Canon 15 fish eye - Canon niffty 50 f/1.8 - Canon 430 ex II - Manfrotto 680B Monopod - Sandisk extreme III 4 GB - and some odds and ends my flickr-
http://www.flickr.com/​photos/simonturkin/ (external link)
strobe ­ monkey
May 31, 2009 17:21 |  #7
just a small piece of blu tac between the thread of the hood will do the trick
R5, RF 85 f1.2L, RF 50 f1.8, 6D, EF16-35 F4L IS, EF50 f1.4, EF 100 f2.8 L Macro IS
Rafromak
May 31, 2009 18:02 |  #8
A very small dab of clear RTV silicone over the hood's thread (remove the hood, and create just a little bump on the thread), then let it sit overnight to fully cure. This stuff will eventually come off, but it's sort of soft or rubbery, and won't damage plastics.
7D, 5DII
Double ­ Negative
*sniffles*
May 31, 2009 18:12 |  #9
Forget the glue and paints and such. All you need to do is dimple the plastic bayonet of the hood... I did this on one of my hoods several years ago and it's never been loose again.
La Vida Leica! (external link) LitPixel Galleries (external link) -- 1V-HS, 1D Mark IIn & 5D Mark IV w/BG-E20
15mm f/2.8, 14mm f/2.8L, 24mm f/1.4L II, 35mm f/1.4L, 50mm f/1.2L, 85mm f/1.2L II, 135mm f/2.0L
16-35mm f/2.8L, 24-70mm f/2.8L, 70-200mm f/2.8L IS, 100-400mm f/4.5-5.6L IS, Extender EF 1.4x II & 2x II
5,133 views & 0 likes for this thread, 7 members have posted to it.
1115 guests, 119 members online
