Thread started 31 May 2009 (Sunday) 17:11
Multi–spot metering – EOS–1 series Cameras
Palladium
May 31, 2009 17:11 |  #1
Found this while surfing around...it's next on my list of "learns how to do it".
If you shoot with one of the EOS–1 series cameras, there is a little known function you can use – multi–spot metering. The cameras have the four common metering modes – Evaluative, Partial, Spot and Centre–weighed, but a fifth, Multi–spot, gives you more control of your exposures. If you set the camera to spot metering, you can use the FEL button to register up to 8 spot metering points from within the scene. The camera will adjust the exposure based on these spot meter readings and provide a balanced exposure. It requires practice to make the most of this setting, but can provide exposure metering in situations where other methods may not be as accurate.
more tips can be found here
http://cpn.canon-europe.com/content/tip​s_from_the_pros.do (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
May 31, 2009 18:15 |  #2
The beneft of multi spot metering is, according to my experience, that the camera will not only measure, but also remember the measurements of up to eight points. It will also show you the relationship between these points graphically on the exposure scale to the right of the viewfinder. This is one of the main differences between a 1D-series camera and the other models.
By measuring the points that are interesting to you in the image you are planning, you can make sure that they are taken into account for the exposure calculation. You can also adjust the exposure with the exposure compensation control.
The time-out may be a bit short, but the 1D-series cameras allow you to change that.
My personal experience from multi-spot metering is from the Canon T90 (the first camera to support this function), but the principle is the same.
Anders
datadump
May 31, 2009 19:03 |  #3
yup i use this all the time .. outstanding feature...
datadump
Greg_C
Gallery: 10 photos
Joined Nov 2005
May 31, 2009 22:47 |  #4
cool, thanks for the tip.
Greg
Blog (external link) | Photogallery (external link) | 1DmkIV + other stuff
Sanity is a madness put to good use.
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
May 31, 2009 22:51 |  #5
Hmm, this is one I haven't tried yet... thanks for posting :)
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
Steveod
Jun 01, 2009 00:53 as a reply to  @ Jim G's post |  #6
I have recently learnt a bit about spot metering at my photo class I decided to see what it said in the 1D user manual on the subjet.I have found it agreat improvement over normal spot metering[not that I am that great at this anyway]and certainly often a big improvement over what the camera would think it required,Take three pics of a landscape for example, EV metering,spot,and multi spot and you can see what I mean
Steveod:shock: 1D Classic,1Ds, 400D. EOS-1n, EOS-5 Minolta Autocord,Yashica-A,Yashica-mat 66 Yashica-mat 124G ,Rolleicord IV & VB ,Mamiya C3,Mamiya C33, and a heap of other gear I keep collecting and collecting,Hi I am Steve and I am a photoholic http://www.flickr.com/​photos/steveod2007/ (external link)
The ­ Moose
Jun 01, 2009 01:50 |  #7
I assume this is only on the 1D3 and 1Ds3 rather than the 1D classic? :p But it would be handy feature to use once you get to know its strengths.
Steveod
Jun 01, 2009 02:52 |  #8
The Moose wrote in post #8026641 (external link)
Feature of 1D.Set to spot mode, focus ,point focus centre spot on lightest area and press FEL button ,find a dark lit area ,press FEL button,point at a different lit area again press FEL ,these light reading [Up to 8 readings]are stored until the shutter is released.have fun.
The ­ Moose
Jun 01, 2009 02:57 |  #9
Steveod wrote in post #8026828 (external link)
Didn't think it would be on the Dinosaur! Thanks, I'll have a go tomorrow since it's already pitch black here :p
apersson850
Gallery: 35 photos
Jun 01, 2009 03:04 as a reply to  @ Steveod's post |  #10
Cameras like the Canon T90, EOS 3, EOS 1V and all marks of EOS 1D/1Ds support this feature.
Anders
Steveod
Jun 01, 2009 03:16 |  #11
The Moose wrote in post #8026837 (external link)
Hey Moose turn your ISO up and use it inside ,take a camera exposed pic first and compare
ICee
Jun 01, 2009 05:16 |  #12
I know the 1Dmkii has it as I've used it a few times.
Palladium
Jun 02, 2009 19:35 as a reply to  @ ICee's post |  #13
Here's a good link explaining things with a Mark III
http://www.usa.canon.c​om …uctID=109&artic​leTypeID=5 (external link)
Multi-Spot Metering with Mark III Cameras
An often-neglected feature on Canon’s professional EOS-1D and EOS-1Ds series cameras is their ability to perform multi-spot meter readings, when the camera is set to the spot metering mode. This feature, unique among digital SLRs (as of June, 2008), allows a critical photographer to take more than one spot meter reading of a scene. And the key is that the camera will automatically calculate the proper exposure as successive readings are taken. Up to eight separate spot readings of different parts of a scene can be averaged automatically in this way.
ccp900
Jun 02, 2009 23:51 |  #14
just a question, the description sounds like it is a mini evaluative metering mode but you have perfect control as to what will be used to average the exposure....correct?
how different (accuracy wise) is this from taking a spot meter reading on something i know the reflectance value of and adjusting the exposure compensation to put the subject on the correct zone?
i thought the general concept was, if you for example put the white on zone 6 or 7 then all the other colors would follow and would be exposed for correctly.....wouldnt averaging an extreme white and a black lead to an exposure compromise?
[Sony A7R Mark 3 | Sony A7S | Sony Zeiss 16-35m f/4.0 | Sony FE 85m f1.8 | Sony FE 20m f1.8 G | Samyang 18m f2.8 | Samyang 45m f1.8 | Zeiss Batis 40m f2 | Sony FE 28m f2 | Sony Zeiss 55m f1.8 | Sony FE 28-70m f/3.5-5.6 | Helios 44-2 | Helios 44-3 | Nikon 105m f/2.5 AIS | Contax Zeiss Planar 50m f1.7 | Contax Zeiss Planar 100m f2 | Voigtlander Nokton 40m f/1.4 | Canon 24-105m f/4.0L | Canon 85m f/1.8 | Sigma 30m f/1.4 | Canon 10-22m f/3.5-4.5 | Canon 100m f/2.8 Macro USM | Canon 580 EX Ver 1.0]
2,530 views & 0 likes for this thread, 9 members have posted to it.
1025 guests, 107 members online
