If I have the older pocket wizard plus transmitter and and pocket wizard receiver, and wanted to add more pw's....I can buy the newer pw plus 2 transceiver models and would still be able to fire it from the transmitter I already have, correct?
bakatari Senior Member 459 posts Joined Aug 2008 Location: Seattle More info | Jun 03, 2009 11:26 | #1 If I have the older pocket wizard plus transmitter and and pocket wizard receiver, and wanted to add more pw's....I can buy the newer pw plus 2 transceiver models and would still be able to fire it from the transmitter I already have, correct? 5d2
jrotello Member 104 posts Likes: 1 Joined Nov 2005 Location: Roscoe, IL More info | Jun 03, 2009 12:05 | #2 Yep. Your old transmitter will fire the Plus II transceivers. NOTE: I don't own PWs, but I am pretty sure this is the case.
rikaro Member 153 posts Likes: 2 Joined Jul 2006 Location: Vancouver More info | Jun 03, 2009 14:04 | #3 I believe most PW models are compatible to each other, just that with the new ones they don't give TTL with the old ones Matt Kwok
| Latest registered member is SteveeY 1698 guests, 167 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
