FORUMS Post Processing, Marketing & Presenting Photos The Business of Photography
Thread started 06 Jun 2009 (Saturday) 12:23
A More Complex Watermark
ryant35
Gallery: 16 photos
Jun 06, 2009 12:23 |  #1
I currently watermark all my images with ACDSee Pro with just text of my URL right in the middle of my pictures. It's quick & easy through batch processing and I even resize & sharpen all the photos just for my website.
Now I'm looking to do something more complex and add the logo of the race series the watermark in Photoshop CS 2.
The first draft below consists of a logo that was previously masked out and was pasted into the current drawing by duplicating the layer from the other it's own file into the new file. So I didn't have to mask the image again.
There is also a rectangle with a black color overlay, with the layer set to 47% opacity. The text is just letters for now but my actual logo has a bunch of layer style settings and I also need to duplicate that layer into the new drawing to keep my settings.
Now with all that explained I assume an action is the best way to automate this, but all this duplicating layers probably won't work. And if it does I can imagine it would take a while to process.
What if I where to remove the photo from this Photoshop file and use it as a template and create an action to insert it over each photo.
What are your thoughts?
IMAGE: http://i88.photobucket.com/albums/k173/ryant35/IMG_0880.jpg
5DMK4, 7DMK2, 24-104mm f/4 L, 70-200mm f/2.8 IS II, 100-400mm f/4.5-5.6 IS MK2, 17-40mm f/4, 100mm f/2.8 Macro, 35mm f/1.4,1.4X & 2X TC III 580EXII
www.ryantorresphotogra​phy.com (external link)Photography Facebook Fan Page (external link)
jra
Jun 06, 2009 19:28 |  #2
I can't help you with your actual question but I did have a thought....Could you run into any copyright infringment issues by using that logo on your photos?....of course, you may have permission or not even need it in the case (I don't know)....just something I thought I would bring up :)
ryant35
Gallery: 16 photos
Jun 06, 2009 19:36 |  #3
jra wrote in post #8062614 (external link)
A bunch of the other photographers are doing it, and it would help the series by identifying the photos shot at their races. I'm not going to sell any images with the logo.
seiginoyami
Jun 07, 2009 01:57 |  #4
ryant35 wrote in post #8060924 (external link)
1st, are all the images you're saving going to be the same size? Or a set of a few different sizes? eg 800x600, 600x800 or anything like that?
2nd, Is it possible for you to take that watermark and make it a single layered psd file? (re-read what you wrote and I think thats what you were saying anyway so I guess you can, so short answer is yeah that should work if you just use it as a template)
If so then you can set the action and automate it where you just copy and paste it, then batch run it over every image you want. I think that should work. I used to watermark a lot of pictures for work using that method when our watermarking program went down.
There might be an easier way than that though, not too sure.
Canon XTi
50mm/1.8
55-250mm/4-5.6
happyfeet
Jun 07, 2009 06:06 as a reply to  @ seiginoyami's post |  #5
I like putting water mark too.
opacity is my favorite concept on my digital photography.
OKC Wedding Photographers (external link)
ryant35
Gallery: 16 photos
Jun 07, 2009 09:53 |  #6
seiginoyami wrote in post #8063999 (external link)
1. yes the images are always 800x600, that is my standard and I made the watermark to fit that size.
2. Yes I could make it 1 layer, it's currently isn't 1 layer but I could save it as a different file and flatten the layers. I just want to be sure to keep the original so I can modify it later.
I'll look into batch processing it, I haven't used that function in PS yet. Batch will be really needed as I will be adding it to 1000+ images at a time.
Thanks for your help.
dekalbSTEEL
Jun 07, 2009 17:52 |  #7
Will your name stand out against all the backgrounds you may get? As it is here, the red is a little tough to read.....and should include your domain name....
Grippy 30D, Tokina 300f4, Sigma 18-50f2.8, Canon 70-200f4L, thrifty50mkI, PM7500DX
Jon Gee Photography.com (external link)
Karl ­ Johnston
Jun 07, 2009 18:00 |  #8
I think your name should be in black, I can't even read that.
Adventurous Photographer, Writer (external link) & Wedding Photographer (external link)
ryant35
Gallery: 16 photos
Jun 07, 2009 23:58 |  #9
dekalbSTEEL wrote in post #8067112 (external link)
I do usually use my domain name, and I have been working on a better logo than that hard to read font. I guess until I come up with something better I should just go simple. I also darkened the stripe so it stands out over any photo. Most of the shots I'll use this watermark for will be similar to the ones I've posted here, all most all with dirt or sky at the bottom.
IMAGE: http://i88.photobucket.com/albums/k173/ryant35/LOORSWatermark.jpg
Nouks
Jun 08, 2009 07:07 |  #10
You might want to watch this video tutorial on watermark actions in Photoshop. It's really useful: http://russellbrown.co​m/tips_tech.html (external link)
Loooonngggg page, so search for "digital watermark branding".
I used to be Gebruikersnaam.
Gearlist: 1D2, resurrected 20D, 400D, 16-35L, 28-70L, 70-200L, 85 F1.8, cute 18-55, dead 24-70 Siggie, 2 flashlights, expensive bags and loads of CF-cards.
Website (external link)Portfolio (external link)Archive (external link)
ryant35
Gallery: 16 photos
Jun 23, 2009 00:39 |  #11
Ok so I can't figure out who to create the action to insert my 1 layer PSD file on top of the image. I open an image, then switch to the already open watermark psd file and on the layers tool bar I right click on the layer and select duplicate layer. Then I select the photograph that is open, than ok. The watermark shows up perfectly. Then I stop the action recording. When I use the automate batch process and I get an error because the action is actually looking for the image number that I used when I created the action instead of the image used in the batch process.
I can't seem to figure our how to create an action to duplicate the layer without another image file open to duplicate it to.
Is there a way to insert or merge the watermark psd file over the jpeg file?
tim
Light Bringer
Jun 23, 2009 06:19 |  #12
Easy. Save the watermark as a psd file. Make an action that opens the other image, uses file -> place, uses a blending mode if necessary. You might need to place the logo and the black bar from separate psd files in order to use different blend modes. Use the layer alignment commands and the nudge (ie cursor key press when transform tool selected) to get a layer into the right position, then align the other with it. It's something like that anyway, it will probably take a few hours to get right. Here's a screenshot of a similar action I use. Note this version is run interactive or through image processor, you need open/close steps if you want to run it from batch.
You can ask me what each step does if you like, the chances are I won't remember but i'll guess.
2,363 views & 0 likes for this thread, 8 members have posted to it.
925 guests, 108 members online
