Thread started 07 Jun 2009 (Sunday) 10:30
Rear mount Gelatin ND filter for the EF14 L lens?
The ­ Ghost ­ of ­ FM
Jun 07, 2009 10:30 |  #1
I recently purchased the EF14mm f/2.8 L II USM lens and absolutely love it! But that's not what this thread is about!
What I'm looking for is a gelatin rear mount ND filter for it and can't seem to find any direct products out there for this lens?
What is the approach here? Do I just buy a large ND sheet and cut it to size? If so, who makes the best sheets of this stuff and how does one make an intelligent decision about who's sheets are better or worse?
I've seen these sheets that seem to be aimed at users who want to put them in front of their lighting devices but nothing marketed specifically for mounting on lenses. I knew that the mount system on the back of my lens appears to be looking for something that is quite thin but the manual doesn't state what the thickness should be and doesn't make any recommendations as to which gelatin filter product to buy...Canon doesn't appear to offer this product?
Have any of you searched out, found, cut, mounted and successfully done what I am attempting to do? If so, please chime in with product suggestions and where to find them. I'm basically looking for ND filter strengths of 3 and 6 stops.
Cheers!
GEAR LIST l WEBSITE (external link)
bohdank
Jun 07, 2009 11:07 |  #2
I'm curious also but for the 17-40. Most likely it's the same thing.
monty28428
Jun 07, 2009 11:21 |  #3
Just buy 3"x3" gel and cut to fit -- Kodak Wratten's come to mind.
BTW -- the 17-40 does not have a rear gel holder bohdank... I would just use a normal filter.
nureality
Jun 07, 2009 12:04 |  #4
Why not get a high quality ND filter for the front of your expensive lens instead of slapping a cheapo-IQ-stealing piece of gelatin on the back?
I only use gels for flashes.
Alan "NuReality" Fronshtein
Gear List | PBase |  (external link)flickr (external link)
Lots of Fun, Lots of Laughs, Happy Trigger Finger!
monty28428
Jun 07, 2009 12:12 |  #5
Because the 14mm doesn't accept them nureality... be about the same as trying to slap one on in front of your fisheye.
bohdank
Jun 07, 2009 13:00 |  #6
Don't know what you mean by "doesn't" accept them. I haven't tried my CPL on my 17-40, which I just got. So, your post prompted my curiosity and I tried it. Doesn't seem to have any issues. Using DPP's lens correction, which also corrects vigneting for a specific lens, without a filter, the edges with the CPL on are fine.
Shuko
Jun 07, 2009 14:29 |  #7
Many people use filters on Nikon 14-24, so it's just about imagination etc. ;)
One example: http://www.flickr.com …/13847280@N03/2​655841619/ (external link)
www.miikajarvinen.fi (external link)
20DNewbie
"don't listen to me, I'm an idiot"
Jun 07, 2009 14:49 |  #8
monty28428 wrote in post #8065445 (external link)
Hmm, mine has one. I've always been curious about using it to, this may warrant a trip to the local photo store tommorow.
Christian.
Feedback: POTN - FM (external link)
Jun 07, 2009 18:09 |  #9
Shuko wrote in post #8066257 (external link)
The lens in question in this thread is the 14L from Canon. This lens has a permanently attached hood so that Cokin monstrosity wouldn't work on it.
Cheers!
Jun 07, 2009 18:15 |  #10
OK, so one vote for the Kodak 3 x 3 gels. Thank you! :cool:
And, I do own a 17-40L as well and there is in fact a rear gel mount, very similar to the back of the 14L. So, the info can be applied to both lenses with regard to gelatin filter usage. The only caveat being that the 17-40 can accept normal front mounted glass filters which would be of superior quality and durability to a floppy gel filter which can cause ghosting effects should it deform in shape with age and temperature conditions.
Cheers!
eth3rton
Gallery: 27 photos
Jun 07, 2009 21:42 |  #11
I've wondered about a filter for this lens as well. Do they make a IR gelatin type filter?
sheawyatt
Jun 07, 2009 22:09 |  #12
That's on a DX format camera though, so such a setup would likely vignette heavily on FF.
If you can find a booklet of those free Lee gelatin samples, I'm pretty sure there will be at least a couple strengths of ND included that you can cut to the right size.
EOS R5 | RF 15-35 f/2.8 | RF 24-70 f/2.8 | RF 70-200 f/4 | EF 400 f/4 DO II | EF 1.4x III |
Marketplace Feedback: Link
www.sheawyatt.ca (external link)
5,409 views & 0 likes for this thread, 8 members have posted to it.
1014 guests, 107 members online
