Thread started 07 Jun 2009 (Sunday) 17:28
Samsung SyncMaster 266BW
BigAlz1
Jun 07, 2009 17:28 |  #1
Anyone out there have this monitor. I think this monitor is ok for editing photos but I am sure not the best. It's a 2ns 22" LCD and my biggest issue is brightness. I have calibrated this monitor the best I can without spending money for a pro tool.
If anyone has this monitor or has an opinion about it, and if someone has an opinion about a better monitor please chime in. I am a starting portrait/candid photographer but I am quiet anal about accuracy.
Eos 7D, 40D w/70-200L 2.8 IS, 50mm 1.4, Nifty Fifty II, 100MM 2.8 Macro, 18-135mm IS , Sigma 30mm 1.4 , Sigma 18-35 1.8 ART 580ex II
James ­ Salenger
Jun 07, 2009 18:43 |  #2
You will achieve the best results if you spring for a calibration device. Spyder III
is affordable and does a good job. There is more adjustments than brightness
that will transfer to your prints, the Spyder II will make these adjustments so
you will get an accurate print that closely matches what you see when you edit.
http://www.amazon.com …61&ref=pd_sl_9m​a8kfzmf7_b (external link)
I read the review on Amazon, and was quite suprised at the fellow's difficulty. The included software
was rather simple and straight foreward and instructs you step by step for installation (you just run the
disc) and click. The suction cup he referred to, is for glass front CRT monitors.
I may not be the village idiot, but I'll do until
he gets here.
ctcks
Jun 08, 2009 12:35 as a reply to  @ James Salenger's post |  #3
Before you buy a Spyder or Huey or whatever, check out this link for the Samsung monitor support site. You can download a proper calibration profile for your monitor. Then you can select the resulting profile as your monitor profile in Lightroom or DPP. I noticed that once I had my printer profile selcted based for the photo paper I was using, and then my monitor profile selected (the downloaded one), my printed pictures were right on. Hope this helps. Oh yeah, I have the Samsung Syncmaster 931B. Hope this helps: http://www.samsung.com …itors/magictune​/index.htm (external link)
Camera: Canon 5D, Canon EOS 40D
Glass: Canon 24-105mm f4; Canon 50mm 1.8; Tamron 17-50 2.8; Sigma (macro) 28-80 3.5-5.6; Sigma 100-300 4-5.6; .
Flash: Canon Speedlite 580EX II, Canon Speedlite 430EX II
www.dailyaudiobible.co​m (external link)
fanorama
Jun 08, 2009 14:44 |  #4
James Salenger wrote in post #8067394 (external link)
I've just read the review too.
ChasP505
"brain damaged old guy"
Jun 08, 2009 14:50 |  #5
ctcks wrote in post #8071647 (external link)
It's not a "calibration" profile. You can get the standard display profile for your Samsung, but certain models of Samsung LCDs are notorious for having bad display profiles which cause bad color shifts in Photoshop. On all my uncalibrated Samsung monitors, I use the default sRGB profile as the display profile. Of course, when you actually calibrate your monitor, you'll be using the custom profile you created.
Chas P
RichSoansPhotos
Jun 08, 2009 15:06 |  #6
Nope, don't ever use the color management for your monitor, it will end up looking weird, in the color management of your computer, select the sRGB as your default
ChasP505
Jun 08, 2009 15:43 |  #7
400dabuser wrote in post #8072570 (external link)
I'm not talking about using the monitor profile as the RGB working space in Photoshop Color Settings. I'm talking about using the display profile provided by Samsung as the default system display profile. You won't notice anything different in Windows or IE, but when you open an image file in Photoshop, you'll get a terrible color cast. So I suggest setting the default sRGB profile as the default system display profile in Windows until you can build a custom calibration profile.
Chas P
RichSoansPhotos
Jun 08, 2009 15:48 |  #8
ChasP505 wrote in post #8072784 (external link)
The display profile supplied by samsung messed up my viewing qualities
I normally use Adobe RGB when using Photoshop
ChasP505
Jun 08, 2009 15:51 |  #9
400dabuser wrote in post #8072818 (external link)
You set your system default display profile to Adobe RGB?
Chas P
BigAlz1
Jun 08, 2009 23:01 |  #10
I have things all set close to par, I have my colors, and brightness/contrast set well and everything I edit looks same on print as does in Photoshop and IE.
I was really looking for more of a monitor upgrade suggestion then anything.
BTW, I use AdobeRGB too. I use that profile on my camera/monitor/Photosh​op/DPP and my printer and everything comes out just as I edit it. I have even had a pro lab print my work and again right on par.
Is there a better way?
krb
Jun 08, 2009 23:13 |  #11
If the correct profile could simply be downloaded off a web site then the manufacturer would have included that profile with the driver and there would be no need to download anything. The color output changes over time and that's why you should buy a calibration tool and use it on a regular basis to keep things adjusted correctly.
-- Ken
Gear list
ChasP505
Jun 09, 2009 07:33 |  #12
BigAlz1 wrote in post #8075129 (external link)
OK then... There's a long thread in the Computer section about the Dell 2209WA, an IPS display for those of us on a restrictive budget. I believe you can still get one for the special price of $212 USD shipped. Keep the 266BW around as a second monitor for video gaming and to contain your PS palettes as you edit photos in full screen on the Dell.
The monitor profile and your chosen color workspace for photo editing are two different things. But if the monitor profile is corrupt, then Photoshop will not render colors accurately.
Chas P
5,351 views & 0 likes for this thread, 7 members have posted to it.
1061 guests, 104 members online
