FORUMS Photography Talk by Genre Macro Talk
Thread started 08 Jun 2009 (Monday) 10:27
Help getting started in macro
tjaudet829
Jun 08, 2009 10:27 |  #1
I know very little to nothing on macro photography...except it can be very cool.
I talked with a friend recently who was mentioning about a male to male stop dow ring that he would mount his 50 1.8 on a 18-55 kit lens.
Does this sound right?
I tried just holding my 50 to my kit lens which seemed to work but the image was not what I expected.
Would a mf 50 1.8 be handy in this?
I just saw one on craigs list for $20
Any help with aperture settings and other general info would be greatly
appreciated.
Picture is of skull candy earbuds.
Jeff
50D, EF-S 18-55 (Kit), EF-S 55-250, EF 50 1.8, 430ex, 70-200 2.8 L, EF 2x II TC, EF 1.4x TC,
EF-S 15-85
LordV
Jun 08, 2009 12:45 |  #2
You need a male /male reverse coupler which fits the filter thread sizes of the lenses you want to use.
Brian V.
Macro Hints and tips
tjaudet829
Jun 08, 2009 13:09 |  #3
LordV wrote in post #8071699 (external link)
Brian V.
ok, and then the 18-55 goes on the camera body?
Thanks,
Jeff
EF-S 15-85
DigitalSpecialist
Jun 08, 2009 13:24 |  #4
Actually there are many ways to shoot macro. Lord V gave you the cheapest/oldest route that the old photogs used. The other inexpensive way is using rings to extend the lens from the camera body.
Good luck!!!
JIM
EOS 630, 1N, 1DsMkII, and 5D/wgrip and some L glass.....
goldboughtrue
Jun 08, 2009 13:31 as a reply to  @ DigitalSpecialist's post |  #5
Kenko extension tubes are going to be the next cheapest option other than a dedicated macro lens. I'll save you the trouble of trying to figure out Canon vs. Kenko in this case-since there isn't any glass in an extension tube, it does not matter which you choose. Kenko is a lot cheaper and works perfectly. Just do a search on "kenko tubes" and you'll get a ton of threads here.
http://www.pbase.com/g​oldbough (external link)
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
John_B
Gallery: 120 photos
Jun 08, 2009 16:45 |  #6
tjaudet829 wrote in post #8070928 (external link)
tjaudet,
What were you expecting? ???
Keep in mind that because the 50mm f/1.8 is smaller then the 18-55 lens in filter size you are more likely to get strong vignetting, where the corners come out dark like shown in your photo.
I personally suggest a set of Kenko extension tubes.
Sony A6500, A6000, Apeman A80, & a bunch of Lenses.............  (external link)
click to see (external link)
tjaudet829
Jun 08, 2009 21:40 |  #7
John_B wrote in post #8073148 (external link)
tjaudet,
Thanks John that's the comment I was looking for. The strong vignetting.
if you don't mind me asking what do I currently have and what addition gear would be required to just get started and not drop$400 on a macro lens or even $150 on tubes?
Just a reversing ring with the kit lens?
Or a male/male to adapt the 50 on my kit lens?
Thanks,
Jeff
EF-S 15-85
LordV
Jun 09, 2009 07:48 |  #8
tjaudet829 wrote in post #8074728 (external link)
Thanks,
Jeff
Suspect I would go for a reverse coupler to fit your 50mm lens onto your 70-200 lens that would give you a zoom macro lens going from 1.4:1 to 4:1 approx. The 70-200 would go on the camera body.
Brian v.
John_B
Gallery: 120 photos
Jun 09, 2009 07:53 |  #9
tjaudet829,
Sorry, but the best option (in my opinion) is save for a macro lens or get extension tubes.
If you don't mind cropping then the m/m adapter is probably the better as you will still have control over aperture.
Either method you will notice its very hard to get light to the subject which will result in slow shutter speeds. An external flash with extension cord is really almost a requirement.
Macro photography is not cheap ;)
tjaudet829
Jun 09, 2009 08:29 |  #10
John_B wrote in post #8076462 (external link)
tjaudet829,
Thanks for the input.
I really just want to give it a go without remortgaging the house...wait can't do that either.:)
I do have a external flash already so I need a cord and a ring just to play around with this.
Thanks,
Jeff
EF-S 15-85
tjaudet829
Jun 09, 2009 08:31 |  #11
LordV wrote in post #8076446 (external link)
Brian v.
thanks LordV. I will look into the rings and a flash cord.
EF-S 15-85
CanonBoy3
Jun 09, 2009 11:04 |  #12
They have a really helpful site on this topic. Go to PROPHOTOLIFE.COM and search the episode "macro" for it.
Canon 20d, 50d, and 5d
50mm1.4 / 17-40 F4L / 16-35 F2.8L / 28-135 F3.5 / 24-70 F2.8L / 85mm 1.2L / 100mm Macro F2.8
tjaudet829
Jun 09, 2009 12:14 |  #13
CanonBoy3 wrote in post #8077530 (external link)
on the list of things to do....thanks
EF-S 15-85
tjaudet829
Jun 11, 2009 10:44 as a reply to  @ tjaudet829's post |  #14
Well I think I found what I was looking for in this thread.
https://photography-on-the.net/forum/showthre​ad.php?t=634557
Here is a sample
just hand held no flash with kit lens.
as always cc welcome
EF-S 15-85
John_B
Gallery: 120 photos
Jun 11, 2009 13:39 |  #15
tjaudet829,
Is that with a home made extension tube like in the link you posted? ???
If it is the one of the negatives is you loose control over aperture (f/stop). You can manually set it but then it becomes harder to focus your subject because the lens is always stopped down which really gives a very dark viewfinder. The general math is the extension needs to match the lens length to give true 1:1 macro.
But if your happy with the home made tube, then enjoy it :)
4,153 views & 0 likes for this thread
Latest registered member is vini81
931 guests, 279 members online
