Hi all,
Can someone out there explain the difference between these two colour spaces. Which is better etc and what are the pros and cons.
Cheers
redsnapper Senior Member More info | Jun 08, 2009 19:38 | #1 Hi all, If you do what you always do, you get what you always get.
snakeey11 Mostly Lurking 11 posts Joined Sep 2008 Location: Santa Clara, CA More info | Jun 08, 2009 20:03 | #2 -mike
lungdoc Goldmember 2,101 posts Likes: 1 Joined May 2006 Location: St. Catharines, Ontario Canada More info | Jun 08, 2009 20:17 | #3 See similar threads below but the short answer is a) if you don't know very specifically why you might need Adobe RGB use sRGB and b) unless using either sophisticated home printers that accept aRGB or a pro lab that does; use sRGB - most labs like Costco etc. won't take aRGB. Mark
Rey Senior Member 571 posts Likes: 2 Joined Mar 2006 Location: SoCal More info | Jun 08, 2009 22:53 | #4 Adobe RGB has a wider gamut. Canon 5D MKII • BG-E6 • Canon EOS-M • Canon 85mm F1.2L II USM • Canon 100mm F2.8L Macro IS USM • Canon 16-35mm F2.8L II USM • Canon 24-70mm F2.8L USM • Canon 70-200mm F2.8L IS USM • Sigma 50mm F1.4 ART • Canon Speedlight 600 EX-RT • Canon Speedlite 580EX II • Canon Speedlite 430EX II • Gitzo 3530 • Really Right Stuff BH-55 LR
Jon_Doh Senior Member More info | The adobe has a greater range of colors and your photos will look better printed. sRGB with fewer colors does better with websites displaying your colors. A few years back Kodak entered the fray with their Prophoto that has an even greater color range that helps with printing. I use a Kodak Brownie
putz Member 91 posts Likes: 10 Joined Apr 2009 Location: Plano, Texas More info | Jun 09, 2009 10:08 | #6 Adobe RGB as Rey pointed out has a wider gamut of colors, which means that they can more accurately represent the true colors of your photos both on the computer and in print.
rral22 Senior Member 885 posts Likes: 1 Joined Jul 2008 Location: Saskatchewan, Canada More info | If you don't have a specific reason to use Adobe RGB, use sRGB.
lungdoc Goldmember 2,101 posts Likes: 1 Joined May 2006 Location: St. Catharines, Ontario Canada More info | Jun 09, 2009 10:55 | #8 I think it's simplistic to simply tell people that wider gamut is better and will look better. There's ample discussion of this in prior threads but unless you use and understand colour management very well I doubt there's benefit for most - certainly none if your photos are destined for the web or for most non-professional print services. Mark
defordphoto MKIII Aficionado 9,888 posts Likes: 3 Joined Oct 2002 Location: Pacific Northwest More info | Printing aRGB photos on a non-aRGB printer will look washed and colorless. Normally, the only time most (not all) people will want to use aRGB is for print magazines, etc. Now, if you're shooting and are not sure whether you will end up needing aRGB or sRGB, then shoot aRGB and convert to sRGB in post-processing. defordphoto | Celebrating the art of photography®
Jun 09, 2009 12:07 | #10 defordphoto wrote in post #8077517 Now, if you're shooting and are not sure whether you will end up needing aRGB or sRGB, then shoot aRGB and convert to sRGB in post-processing. Shoot raw and pick whichever you want later. Frank Hollis - Retired mass spectroscopist
CyberDyneSystems Admin (type T-2000) More info | Jun 09, 2009 12:21 | #11 If you shoot RAW indeed you can use whatever you want later.. GEAR LIST
bomzai Senior Member 524 posts Joined Apr 2008 Location: Bothell WA, US More info | Jun 09, 2009 12:36 | #12 CyberDyneSystems wrote in post #8078026 If you shoot RAW indeed you can use whatever you want later.. But that does not answer the question of what to output from your RAW converter.... If you want to though, you can always output your Tiffs in AdobeRGB, then work in PSCS in AdobeRGB workspace.. Why not export in ProPhoto then? I'd say it's the right thing to do for the pictures you are going to spend significant amount of time in PP. Export it in 16bit ProPhoto, PP it and save. Then when you need to "print" it for any type of media, you just resize and convert to corresponding profile, but your original is always in best possible quality. Camera: EOS 5D Mark III, EOS 70D, ™24-70mm f2.8 VC, EF 70-200mm IS f2.8 L II, EF 100mm IS f2.8 L Macro, EF-S 18-135 STM, Σ 12-24 II.
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Jun 10, 2009 08:21 | #13 Have a read here, or in a few of the links from the link in my sig. "I think the idea of art kills creativity" - Douglas Adams
CyberDyneSystems Admin (type T-2000) More info | Jun 10, 2009 13:57 | #14 bomzai wrote in post #8078113 Why not export in ProPhoto then? I'd say it's the right thing to do for the pictures you are going to spend significant amount of time in PP. Export it in 16bit ProPhoto, PP it and save. Then when you need to "print" it for any type of media, you just resize and convert to corresponding profile, but your original is always in best possible quality. Yep, why not? GEAR LIST
| Latest registered member is semonsters 1582 guests, 138 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
