Hi,
Just wondering if anyone uses the silent shooting mode on the 1D M3?
It seems useful for candid shooting and what not, but anybody use it regularly?
Dmab Goldmember 1,260 posts Likes: 33 Joined Mar 2008 Location: Wisconsin More info | Jun 09, 2009 12:18 | #1 Hi, Dan
sevans16 Goldmember 1,005 posts Likes: 5 Joined May 2006 Location: Fresno More info | Jun 09, 2009 12:19 | #2 I used it once for a model/fashion shoot in a public library. It worked fine www.777Photography.com
Pekka El General Moderator More info | Jun 09, 2009 12:19 | #3 I use it all the time. The Forum Boss, El General Moderator
Thalagyrt D'OH. I need to wake up some more. 4,818 posts Joined Jan 2009 Location: Denver, CO More info | Jun 09, 2009 12:22 | #4 I use it on my 1D II whenever I'm in one shot mode; it's the same effect. It's great.
tomd Cream of the Crop 13,282 posts Likes: 31 Joined Jan 2007 Location: I live next to my neighbor More info | Jun 09, 2009 12:23 | #5 |
CyberDyneSystems Admin (type T-2000) More info | Jun 09, 2009 12:24 | #6 The first time I used it, I had set it by accident,. and I was convinced my shutter had broken! GEAR LIST
CyberDyneSystems Admin (type T-2000) More info | Jun 09, 2009 12:24 | #7 tomd wrote in post #8078038 is there a reason NOT to use it all the time? Off the top of my head, I think it reduces your max possible FPS and shutter speed? but I may be wrong.. it might just reduce FPS.. GEAR LIST
Thalagyrt D'OH. I need to wake up some more. 4,818 posts Joined Jan 2009 Location: Denver, CO More info | Jun 09, 2009 12:30 | #8 On the 1D II it's only active in one shot mode so it doesn't affect FPS, and it only affects the mirror's return to the down position so it doesn't affect shutter speed... Did that change on the 1D III?
Jun 09, 2009 12:30 | #9 tomd wrote in post #8078038 is there a reason NOT to use it all the time? So I assume here you use the silent mode rather than regular one shot mode? Dan
MaDProFF Goldmember 4,369 posts Likes: 2 Joined May 2007 Location: East Sussex, UK More info | Jun 09, 2009 12:32 | #10 I have used it a lot, it is the difference of getting a closer shot of an animal or not, and weddings as well it is useful i guess Photographic Images on Brett Butler
stathunter "I am no one really" 5,659 posts Likes: 60 Joined Aug 2006 Location: California & Michigan More info | Jun 09, 2009 12:33 | #11 Can someone tell me how to get this to work on the 1D2? I did not realize there is a "quiet" type mode. Scott
Thalagyrt D'OH. I need to wake up some more. 4,818 posts Joined Jan 2009 Location: Denver, CO More info | Jun 09, 2009 12:33 | #12 stathunter wrote in post #8078088 Can someone tell me how to get this to work on the 1D2? I did not realize there is a "quiet" type mode. Thx. Hook it up to a computer with a firewire cable and enable it with EOS utility, it's a personal function.
stathunter "I am no one really" 5,659 posts Likes: 60 Joined Aug 2006 Location: California & Michigan More info | Jun 09, 2009 12:36 | #13 Thalagyrt wrote in post #8078094 Hook it up to a computer with a firewire cable and enable it with EOS utility, it's a personal function. ok- thanks. Scott
CyberDyneSystems Admin (type T-2000) More info | Jun 09, 2009 12:37 | #14 Thalagyrt wrote in post #8078072 On the 1D II it's only active in one shot mode so it doesn't affect FPS, and it only affects the mirror's return to the down position so it doesn't affect shutter speed... Did that change on the 1D III? On 1D III it's a totally separate "shooting mode".. you get Single shot, L (low) burst and H (high) burst and "Silent".. so it;'s also much easier to get it turned on. GEAR LIST
CyberDyneSystems Admin (type T-2000) More info | Thalagyrt wrote in post #8078094 Hook it up to a computer with a firewire cable and enable it with EOS utility, it's a personal function. stathunter wrote in post #8078110 ok- thanks. And like all personal functions, once you "enable it" from your PC,. you can then disable and re-enable it via the cameras menu.. GEAR LIST
| Latest registered member is semonsters 926 guests, 117 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
