Thread started 09 Jun 2009 (Tuesday) 18:24
So... if I were to move from crop to FF...
mrkgoo
Jun 09, 2009 18:24 |  #1
So I was just thinking - I love the 85mm FL on my 40D. Particularly for MFD portraits. Now theoretically, to get the same FOV on a 5DmkII (pipedream), I'd need something like a 135mm (preferably an f/2.0L, naturally), right?
But can that actually give me the same image equivalent, seeing as I won't be able to focus as close? The MFD is larger for the 135mm, I believe. Is this something to consider, beyond just FOV changes for lenses when moving to full frame?
Do crop cameras get an 'advantage' when it comes to macro then?
gasrocks
Jun 09, 2009 18:43 |  #2
First , it should be simple math. Crop = 1.6 X, FF = 1.0 X. The actual DOF you have changes a bit, so yes, a slight advantage for macro work with crop. But, portraits and macro are perhaps 2 different things.
mrkgoo
Jun 09, 2009 19:08 |  #3
gasrocks wrote in post #8080185 (external link)
I was just wondering that I could possibly not get the same FOV of a 135mm on a full frame camera due to the longer MFD compared to an 85mm on a crop.
DreDaze
Gallery: 45 photos
Jun 09, 2009 19:17 |  #4
mrkgoo wrote in post #8080315 (external link)
you should be able to just slap on an extension tube to lower the MFD...
Andre or Dre
gear list
Instagram (external link)
timbop
Jun 09, 2009 19:22 |  #5
Not exactly. It's not the distance, it's the magnification - the 135 actually has a .19x factor whereas the 85 has a .13x mag on full frame. On the crop cam, then yes you are using a smaller portion of the frame. A simple 1.6 multiplier of .13 would yield a rough estimate of .20x. Not much of a difference, IMHO.
The real difference comes into play if you put extension tubes on the lenses, in which case the 85 would get more benefit from a 25mm tube, for example.
Honestly, though, this is a lot like worrying about the brand of tires that come on your new car. That is, it's probably not why you would choose one car over another. Outside of the analogy, there are a whole lot of reasons to go full frame and plenty of macro lenses to fit it.
Current: 5DM3, 6D, 8mm fish, 24-105/4IS, 35/2IS, 70-200/2.8IS, 85/1.8, 100-400/IS v1, lensbaby composer with edge 80, 580's and AB800's
Formerly: 80D, 7D, 300D, 5D, 5DM2, 20D, 50D, 1DM2, 17-55IS, 24-70/2.8, 28-135IS, 40/2.8, 50/1.8, 50/1.4, 70-200/4IS, 70-300IS, 70-200/2.8, 100 macro, 400/5.6, tammy 17-50 and 28-75, sigma 50 macro & 100-300
mrkgoo
Jun 09, 2009 19:35 |  #6
timbop wrote in post #8080381 (external link)
Hmm. Macro isn't my concern as much.
Ok, let's say the 85mm has a MFD of 0.9m. I take a portrait at 0.9m on a 40D. I like this FOV. Can I get this same field of view with a 135mm on a full frame camera? Would the MFD of slightly more than 1m of the 135mm (honestly, I can't remember the respective MFDs) prevent me from framing the same?
KenjiS
"Holy crap its long!"
Gallery: 542 photos
Jun 09, 2009 19:38 |  #7
mrkgoo wrote in post #8080438 (external link)
Maybe you should try a longer lens
On full frame for portraits you could try a 200mm f/2.8L if the 135 is not sufficient....
The only way to answer your question to be honest is to actually TRY it
Deviantart (external link)
DreDaze
Gallery: 45 photos
Jun 09, 2009 19:49 |  #8
the MFD of the 135L is .9M...the MFD of the 85mm is .85M...doesn't seem like much of a difference to me at all...
either way an extension tube solves any MFD problem...
Andre or Dre
gear list
timbop
Jun 09, 2009 19:55 |  #9
Sorry, I got distracted with my whining kids when I started to write my response. The slightly different MFD won't really make a difference; with the extra few pixels of the 5D you could probably crop down to almost exactly the same FOV you get from the 85 on the 40D. What I can say for sure is that the 135 is in a whole new league compared to the 85/1.8 though. I just got done renting one (literally sent it back today), and it was difficult boxing it back up after using it almost exclusively for a week. Of course, my 70-200/2.8IS was my first love, so I was able to cope with the loss.
As I mentioned, for portraiture the 5D/5D2 combined with a 135L are difficult to top. The 5d/5d2 with 70-200/2.8IS are probably just as good, depending upon if you're a prime or zoom with IS lover. Honestly, the 40D with 85/1.8 are just a notch below.
mrkgoo
Jun 09, 2009 20:00 |  #10
KenjiS wrote in post #8080458 (external link)
Right, you mean go out and but a 5dmkII and a 135mm L? I Wish! :p;)
It's all 'in theory', I was just wondering. I know I can crop and do all sorts of things to achieve the same result, I was just curious.
Of coruse now I know the MFD (thanks DreDAze), it's kind of a moot issue, really.
And timbop, you are supposed to make me NOT want this combo ....:p
Rodinal
Jun 09, 2009 20:13 |  #11
mrkgoo wrote in post #8080047 (external link)
No.
Don't you use your feet sometimes? Keep the lens you love and compensate with your feet, you get to the same result if you actually know how to use them... FOV, AOV, crap, gosh! ppl theorize so much about photography...
1D Mark II • 16-35/2.8L mk I • 24-70L • 70-200/2.8L IS • 50/1.8 • 24-85 • 400/5.6L • 430EX
timbop
Jun 09, 2009 20:20 |  #12
Rodinal wrote in post #8080643 (external link)
No.
You can't walk any closer than MFD... or at least it doesn't do you any good :D
Rodinal
Jun 09, 2009 20:26 |  #13
and how often does this guy focus near the MFD limit?
DreDaze
Gallery: 45 photos
Jun 09, 2009 20:29 |  #14
Rodinal wrote in post #8080721 (external link)
haha...did you read the first post...i think this whole post was strictly about shots taken near the MFD...:lol:
Andre or Dre
gear list
Rodinal
Jun 09, 2009 20:36 |  #15
near MFD, the FOV is 1.2 ft wide... so the guy fills the whole frame with the head of the subject.
Therefore with a 135mm he must step back.
whats the problem?
2,445 views & 0 likes for this thread
Latest registered member is angkorphoto
879 guests, 356 members online
