Thread started 09 Jun 2009 (Tuesday) 18:41
Review: Benro A-269 Tripod
Kamik636
Jun 09, 2009 18:41 |  #1
Hey all, I've decided to write a bit of a review of the new tripod I just bought, the Benro A-269. This will be a short, preliminary review to start as I've only just received it and will base it on my initial findings, and update it later on as I put it through its paces.
To start off I would like to say that this is the first tripod I've owned, mainly because they just don't fit my style of shooting, but an opportunity has come up that will give me the chance to do a lot of landscape shooting, so I figured it was time to buy one. My main criteria for choosing the right tripod was price, then performance. Since I was going to be doing a lot of hiking I also needed one that was pretty compact and lightweight. I went through the usual suspects, mainly Manfrotto, and Gitzo and the like and never really saw one that fit all my criteria(and was affordable!), so I then started looking at lesser known brands, such as dynatran and benro. When I first found the A-269 it sounded almost too good to be true(and that may very well turn out to be the case), but i decided I was going to take a chance and try it out.
So, lets start off with the specs.
Benro A-269M8 Travel Angel
B&H Link - http://www.bhphotovide​o.com …ravel_Angel_Alu​minum.html (external link)
B&H Price - $244.95
The Benro A-269M8 Travel Angel Aluminum Tripod with B-1 Ballhead is a professional-quality tripod that uses lightweight high rigidity aluminum alloy with a wall thickness of 1.5mm. In addition, magnesium is used for all die-cast parts. Despite its lower weight, magnesium is more rigid than aluminum, and has the same strength per volume. The tripod comes fully-featured, and is precisely machined to offer the quality and strength demanded by professional photographers.
Travel Angel A-series tripods feature individual leg angle adjustments, anti-rotation leg design, a reversible center column with spring loaded weight hook, anti dust and moisture rubber leg lock grips, and reversible 1/4"-20 to 3/8" mounting threads.
This tripod features a 180° folding mechanism, where the legs totally cover-up the top plate and "spider", and which accommodates the head inside the folded tripod legs. This allows it to fold up to a shorter size.
• Includes matching professional ballhead with Arca-type quick release, with separate calibrated panning control
• Top-leg diameter of 28mm
• Three leg-angle settings (24, 55 & 80°), to accommodate uneven terrain or awkward shooting situations
• Improved dust and rubber-resistant leg lock design prevents dust or moisture from entering the interior of the leg twist-locks
• Anti-twist leg sections and a grooved center column make setup and breakdown quick and easy
• Removable rubber and stainless steel spike feet provide a secure grip both indoors and outdoors
• Retractable spring-loaded hook can be used to add stability with a sand bag or equipment bag
Specifications
General
Load Capacity - 26.5 lbs (12kg)
Head Attachment Fitting - 1/4"-20 & 3/8" (reversible stud) Maximum Height - 60.9" (154.7cm)
Maximum Height w/o Column Extended - 53.4" (135.7cm) Minimum Height - 14.7" (37.4cm)
Folded Length - 14.7" (37.5cm)
Weight - 4 lbs (1.8kg)
Legs
Material - Aluminum
Leg Stages/Sections - 4/5
Leg Lock Type - Twist
Independent Leg Spread - Yes
Spiked/Retractable Feet - No
Center Brace - No
Center Column
Center Column Type - Sliding
Center Column Sections - 1
Alright, on to the pictures.
Here we have the tripod folded up in the standard way, coming it at around 21" long. Not bad, but not why I bought it.
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6315.jpg
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6316.jpg
Now this is more like it. This is why I bought the tripod, portability.
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6318.jpg
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6319.jpg
So far so good, everything seems to be measuring up to spec. So here it is unfolded with all the legs extended. From the ground to the base of the quick release plate is 54", and with my 5D mounted, the viewfinder sits at 58".
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6321.jpg
Here's a closeup of the B-1 ballhead. It seems to be pretty sturdy and well constructed and has exhibited no signs up creeping or anything else even when i mounted my 6x7.
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6322.jpg
Continued below...
| Canon | Elinchrom |
Kamik636
Jun 09, 2009 18:44 |  #2
Here we see my Bronica 6x7 mounted, using the supplied quick release plate. For reference, the bronica weighs probably close to 3kg.
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6324.jpg
And here it is at an angle, ballhead showing no signs of creep.
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6326.jpg
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6327.jpg
Here's a closeup of the legs mounts. I'm still not sure what type of material they're made of, definitely not aluminum, but they don't feel like any sort of plastic either, so my guess would be some sort of composite, or maybe magnesium like the sticker says on the legs, I'm not sure. Since we're on the topic of legs, I'll mention that the build quality of the legs seems excellent, with the locking collars working smoothly and tightly. They are also pretty quick to set up as well, even having 5 sections, I can wrap my hand around all 4 collars and loosen or tighten them at once.
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6328.jpg
Here's a quick shot of the nice freebie included as well, the carry bag. I wasn't expecting much, but much to my surprise this is actually a really high quality bag. The padding is actually pretty thick, the strap is nice and there's even a nice 8"x4" zip up pocket on the inside.
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6329.jpg
So far it seems like a great tripod that will suit my needs well. I haven't done much in the way of performance testing yet, aside from a few quick tests inside(where it performed admirably I must say). In about a week or so though I'll be leaving town for 10 days of work and I'll have a good chance to put it through its paces then. I'm expecting to run across lots of snow, probably rain, and most likely mud, and I'll be subjecting it to all of that and anything else I(or you) can come up with.
If anyone out there has any questions or requests I'll do what I can to fulfill them.
| Canon | Elinchrom |
squiress
Jun 09, 2009 19:40 |  #3
Thanks for posting this.
Do the legs rotate or do they run in tracks when loose?
I use a 67RB primarily on a 3 series Benro carbon fiber. I will be looking forward to how well your Bronica does on this.
My Stuff
Thoughts-Tripods-Ballmounts-Teardown(TD)Benro KB2 Ballmount
TD Weifeng FT-565H Ballmount-TD Benro C128, C328n6 Tripods
TD Dynatran AT-A105T Tripod-TD Benro MC-68n Monopod
5teve
Jun 09, 2009 19:45 |  #4
Nice, looks just like my C-269!
Squiress -- no the legs do not rotate as there is an anti-rotation mechanism that prevents them from doing so.
5D2 | 35 f/1.4 L | 24-105 f/4 L IS | 70-200 f/2.8 L IS II | 580EXII | Sony RX100-III
Runt808
Jun 09, 2009 21:58 as a reply to  @ 5teve's post |  #5
Looking forward to more of your thoughts about this tripod since I have been considering purchasing one too. I would love to be able to purchase the C series, but alas, the A series will have to do for now. :)
hammmerhead
Jun 09, 2009 22:11 as a reply to  @ Runt808's post |  #6
Thanks for the write up Kamik. This Benro looks perfect for me. I really like the size, weight and how much it will hold. I am concerned about the multiple leg extensions, does it have much flex when torqued. I guess this worries me with that many leg extensions and no center brace. I also am suprised there is no retractable spikes, I guess they could be added.
MAX2
50D | 10-22 | 24-105L | 70-300 IS |SIGMA 30MM 1.4
dan ­ j
Jun 09, 2009 22:20 |  #7
I like the compact size, but those legs look like twigs. I'm guessing they'd be fine for fast exposures, but I'm wondering about long exposures.
dan
5D Mark 2/24-70L/100-400L
Kamik636
Jun 10, 2009 04:54 as a reply to  @ dan j's post |  #8
I took the tripod out today and did some shooting with the 5d and Bronica and am happy to report that the tripod worked beautifully. I was shooting the Bronica at around 1/30sec with my 150mm lens, with the legs fully extended in a grass field with a slight breeze and it held steady. I did some low to the ground stuff and it worked fine. Tryed the 5D with some slower shutter speeds, down to 1/2sec or so and it was steady as a rock.
I have no complaints as of yet, it's done all I've asked so far, so I'm happy. Hopefully it'll keep this up for some time to come.
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6338.jpg
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6341.jpg
| Canon | Elinchrom |
Kamik636
Jun 10, 2009 05:01 |  #9
hammmerhead wrote in post #8081355 (external link)
It doesn't seem to have any flex when the legs are fully extended and tightened down that I've seen yet. If it is a concern though, there is the A-268 model, which only has 4 leg sections instead of 5. It's only about an inch or so longer when folded as well, so, not too big of a difference. I kind of wished it had spikes too, but I guess you can't get everything you want.
Ya, the legs are a bit on the small side, they're surprisingly sturdy though. So far it's been alright for exposures of up to 1/2sec outside, I haven't had a chance to go any slower than that yet.
| Canon | Elinchrom |
squiress
Jun 10, 2009 05:49 |  #10
The C3XX series tripods do come with spikes that screw into the leg bottoms instead of the rubber feet. Gitzo makes you buy them extra. The Benro spikes fit my Gitzo 5 series perfectly.
My Stuff
Runt808
Jun 12, 2009 11:07 as a reply to  @ squiress's post |  #11
Thanks for the update with pictures of it in use out in the field. When you have time, could you post your opinion of its stability for long exposures, say like a night shot?
Headshotzx
Jun 12, 2009 14:31 |  #12
Thank you for the great review. Will be seriously contemplating this tripod for my travel needs at the end of year!
Zexun | Flickr (external link) | YouTube (external link) |
Kamik636
Jun 12, 2009 18:57 |  #13
Runt808 wrote in post #8097022 (external link)
I haven't tested any outdoor long exposure tests yet, I'll have to get on that one, I'm sure it'll do good though. I have tested it inside with some 10-20 sec long exposures, and it's done great so far. I'll see if I can't take it outside tonight for some longer exposures.
| Canon | Elinchrom |
dan ­ j
Jun 12, 2009 20:46 |  #14
Kamik636 wrote in post #8099609 (external link)
I guess it's a matter of what "great" is. On long exposures my old POS video/camera tripod pinpoint stars would turn into circular streaks when I blew up the picture. OTOH, it works great when the exposures are fast.
So, let us know and thanks for the review.
dan
Kamik636
Jun 12, 2009 21:33 as a reply to  @ dan j's post |  #15
Well, here's a quick shot I just took inside. It was taken with my 55mm lens with extension tubes on my tripod, with 2 legs extended and the 3rd set partially extended. I also had the center column extended 4-5". Exposure time was 30 sec at F8, ISO 100. This would be what I mean when I say it does great inside. We'll see how it copes outside though.
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6404.jpg
IMAGE: http://www3.telus.net/dmk61/Tripod/IMG_6404-crop.jpg
| Canon | Elinchrom |
22,359 views & 0 likes for this thread, 12 members have posted to it.
Latest registered member is TomBehnfield
939 guests, 167 members online
