Electric Shepherd wrote in post #8096979
I'll probably have my 70-210 on most of the time, with my kit lens for some wide angle stuff, and plan on shooting wide open with a shutter speed of around 1/640-1/2000 if the light permits a tolerably low ISO [the forecast isn't great!] using AI Servo mode.
Where will you be sitting relative to the courts? The 70-210 is (IMO) a bit short unless you're right on top of the court. If you're close enough, it will allow you to get full body shots of the players shot in portrait orientation and decent shots of forehands/bakhands taken in the near court.
Personally, I think the kit lens will only get you some wider angle shots and won't be of much use for action. It's gonna be pretty loose for anything else.
Even though your 70-210 is a variable aperture lens, I'd still suggest shooting Av with the lens as wide open as it will go, and using the ISO to keep your shutter speeds high enough to stop the action. If the ambient lighting gets too dark, you might have a challenge since you're going to be at f/4.5 fully zoomed so you may need to bump your ISO up over 800. I don't know if the 450D allows fractional ISO stops, so you may be choosing between 800 and 1600.
As far as composition goes, head over here and study the shots taken at the highest level of the game.
http://espn.go.com/espn/apphoto/wire?id=850
Notice they are almost all tight shots, with the player's eyes and usually their racquet and/or the ball.
If the light gets too dim, put away your camera and enjoy the matches, 'cuz you can't fool the Physics of the situation (even in post processing).
