Thread started 13 Jun 2009 (Saturday) 23:30
Noise Ninja and File Size
Obtong
Jun 13, 2009 23:30 |  #1
Hi,
I'm using the stand alone version of Noise Ninja 2. I am using it with Lightroom as an external batch editor. I have been applying Noise Ninja to some of my old 10D files, which results in TIFF files of 42,864 Kb. For some files I just need JPEG's so the TIFF's are overkill. Is there a way configure LR to export files to NN as JPEG's instead of TIFF's, or to generate somewhat smaller files? I have the External Editing preset in LR set to:
  • File Format: TIFF
  • Color Space : ProPhoto RGB
  • Bit Depth 8 Bits/Component
  • Resolution: 240
  • Compression: None
Thanks!
~Dom
Digital: 6D, 5D, 50mm f/1.8 Mk 1, 85mm f/1.8, 17-40L, 24-105L, 70-200L f/4, 550EX, 580EX ii (2), 430EZ (2)
Film: AE-1, A-1, M6, Kowa Super 66
tonylong
...winded
Gallery: 60 photos
Jun 13, 2009 23:53 |  #2
I haven't done this with NN, but you can Export as a jpeg and invoke Noise Ninja as an After Export action (you set these up in a folder that you can open in the After Export drop-down window).
It's been a long time since I did something like this so I'm not sure how it would work with Noise Ninja. Maybe others have more experience here.
Tony
Obtong
Jun 14, 2009 00:59 |  #3
Thanks Tony. That was just what I needed to get started! I created an Export preset to create a Full Sized file to the same folder. I also had it add the new file to LR's catalog. I had the preset stack the new file also. In the Post Processing "After Export" section of the export I had it "Open in another application..." and selected Noise Ninja.
Thanks!
~Dom
tonylong
...winded
Gallery: 60 photos
Jun 14, 2009 01:03 |  #4
Great, Dom, I hope it does the job for you! I had created some things a couple years ago, so I knew it was there, but haven't left Lightroom for "special stuff" for just about that long!
Tony
902 views & 0 likes for this thread, 2 members have posted to it.
966 guests, 182 members online
