Thread started 15 Jun 2009 (Monday) 22:32
Help me with RRS clamp and plates
JRP2661
Jun 15, 2009 22:32 |  #1
Hi everyone,
I have a Manfrotto 490RC4 head, and I would like to change the clamp with an RRS.
First question: Can anyone tell me whether I should go with a 1/4-20 or M6 screw?
RRS clamp selector table does not have 490RC4 on it, and my e-mail to them was replied with suggestion for me to disassemble the head and to find out the type of screw by myself. The problem is I can have both 1/4-20 and M6 screws side-by-side, and I still won't be able to tell which one is which.
Second question: I know that camera plate is camera specific. But what about lens plates? Currently I have two different tripod collars, a Canon and a Sigma. Do I have to buy two different lens plates?
Thanks in advance!
Jon
Joined Jun 2004
Jun 16, 2009 10:23 |  #2
If you disassemble the 490RC4 and try using the screw from the lens plate in place of the one you removed (or try threading the screw you removed into your camera's tripod socket) (don't force it in either case) you can easily tell. You could also pick up a 1/4-20 nut or M6 nut at your local hardware store and see which one threads onto the screw you removed. Again, don't force it - it should go smoothly and easily on.
On the plates for your tripod collars the answer is "Probably". When you go to order from them, you can select your lens and they'll show the correct plate options for it.
Jon
Cocker Spaniels
ben_r_
-POTN's Three legged Support-
Jun 16, 2009 12:36 |  #3
Jon pretty much nailed those answers, I just wanted to add one thing about the lens plates: sometimes you can find a size lens plate that will fit both your lenses, but switching them back and forth is a pain IMO. Its best to get the RRS specific plate for each lens, but if you have to, most of the time you can work with just one.
Lowner
"I'm the original idiot"
Jun 16, 2009 14:13 |  #4
They do offer "universal" lens plates and I use an RRS B86 E plate on both my 100-400 and 70-200L's.
Try searching for thread information on both 1/4" and 3/8" UNC. I found the internet has masses of info on thread dimensions and make identifying which you are looking at easy. None of my kit uses M6 but times change.
Richard
JRP2661
Jun 16, 2009 14:23 as a reply to  @ Lowner's post |  #5
Thanks Jon, Ben, and Richard, for your answers.
ben_r_
Jun 16, 2009 15:23 |  #6
Lowner wrote in post #8120855 (external link)
Very true, I actually did exactly the same as the recommended plate for the 70-200 2.8s and the 100-400 is the same and it will work on a number of other lenses as well.
tgara
Jun 16, 2009 22:28 as a reply to  @ ben_r_'s post |  #7
I would add that the customer service at RRS is very good. Call them up and discuss the issues with them if you are still not sure.
EOS 5D Mark III
EOS Rebel SL1
Full Gear List
871 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is RawBytes
1533 guests, 159 members online
