Thread started 01 May 2005 (Sunday) 20:50
I am getting fed up with this!!!!
jon1996
May 01, 2005 20:50 |  #1
I was a proud owner of a G6 for about 1month now, I have had amazing results 15% of the time, For some reason I can not take a good pic with this camera, I dont know what it is, I will try every setting it has and they come out looking like they are in 320x160 resolution, Whats the deal? I dont know how to get the exif info or whatever it is called, but the pics are grainy as hell!, Outside it does alright most of the time but alot of the pics look like they are really soft almost like a painting, Any Ideas?
thanks,
jon
Canon 20D
18-55 IS, 55-250 IS, 50 1.8,
Panasonic FZ50
Canon G6 with about 40,000 Pics
www.jonsphoto.smugmug.​com (external link)
Barb42
Joined May 2003
May 01, 2005 20:57 |  #2
what resolution are you using?
http://www.barbsmithph​otography.com (external link)
jon1996
May 01, 2005 21:02 as a reply to  @ Barb42's post |  #3
I am using large superfine the higest besides raw
Canon 20D
Panasonic FZ50
mrclark321
Noinker
May 01, 2005 21:04 as a reply to  @ Barb42's post |  #4
Go into your settings and do a reset, then try a few on the auto
setting. I get nice pictures with mine. Here is a sample
Dan
Sony A7R3 & A7R4
Sony 16-35 GM
Sony 55mm 1.8
Batis 85mm
Sony 200-600
Barb42
Joined May 2003
May 01, 2005 21:07 |  #5
Let me offer more - via the menu check the settings with the camera on P. press menu. the resolution should be L, Compression S.
BottomBracket
Joined Dec 2004
May 01, 2005 21:08 as a reply to  @ mrclark321's post |  #6
Perhaps you inadvertently put it in ISO 400. Check to see if it is so, and set it to ISO 50.
Pio
Veni, Vidi, Canoni - I Came, I Saw, I Took A Picture With My Canon
Fotopio.com - Gallery of the Meandering Eye (external link)
I am a leaf on the wind. Watch how I soar.
Barb42
Joined May 2003
May 01, 2005 21:09 |  #7
Check the ISO. It may be too high. I agree with the reset. That can solve a lot of problems.
Barb42
Joined May 2003
May 01, 2005 21:12 |  #8
I used 400 a lot with a G2 I have. It worked well. But a lot of problems can be caused with too messing with different settings. Resets are helpful. I tended to do it every once in a while, just because.
Mannytkd
May 02, 2005 15:17 as a reply to  @ Barb42's post |  #9
Hi there,
I too get the same problem with soft photo's when i view them on the pc, and then i have to sharpen them using software, surley this can't be right. The above person has been advised to reset the camera, where tye hell do you reset it, i can't find a factory default setting or whatever you have to look for.......?
I did take some shots of a bluebell a couple of mornings ago and after just a little tweaking it is spot on colour and sharpness?
Thanks.
Canon 50D | [COLOR=black]18-55 IS | 55-250 IS | Canon EF 100mm USM macro | Canon 50mm MK2 | Tokina 11-16 | Kenko Auto Extension Tubes | Uniloc 1200 series pod | Canon 430EX flash gun | Some filters
www.karls-photography.co.uk (external link)
jon1996
May 02, 2005 17:04 as a reply to  @ Mannytkd's post |  #10
To reset turn it on and hold the menu button for more than 5seconds then you can reset it, I did it last night but have not tried it yet, also I looked at my settings and I had the ISO set at 400 like mentioned, that was my fault,
later,
jon
Canon 20D
Panasonic FZ50
kring
May 02, 2005 19:38 as a reply to  @ Mannytkd's post |  #11
First; can you describe your issues in more detail, or post some examples of the issues your seeing? I can sense your frustration but in order to help we need more information.
In order to address the issue of grainy, We'll need some details about your system. What type (LCD, CRT) and how big of a monitor are you using? How old is your monitor? What type of video card do you have? What is your resolution set to and what is your refresh rate on your monitor? Have you tried printing photo's? If so, via real photo lab printing methods or just an inkjet printer?
You need to realize that 7.1MP is ALOT of pixels and that camera is taking such detail that at 10 feet away it has multiple pixels for a single blade of grass. So when you view it on your screen at 100% it's so magnified that you are zoomed in closer then you ever really should be. I think the grainy issues you are speaking about could be because you've got more powerful of a camera then need. Can you tell us what you are trying to do with your camera? i.e. Point & Shoot family photo's or are you looking to do 24X32 poster prints?
Are you viewing the pictures at 100% zoom on your monitor? if you are then you are limited to your monitors resolution of approx 72 pixels per inch. Or if you are viewing below 100% keep in mind you are viewing a compress thumbnail. If you are viewing above 100% you are zoomed in so much that you will have noise that will never be visible in a print.
I suggest that you take pictures at a much lower resolution, try the 1600X1200 resolution @ Superfine. I be that will look better to you. Or Take one of your current photo's and using a photoshop (or similar) program, resize your photo to 1024X768 and see if that looks much better to you.
The other thing I would ask is that when you are taking pictures that come out grainy... next time look at the LCD display in the bottom left hand corner, do you see an icon there? it will be a camera with quotes at the bottom? That indicates that the picture will require a very stead hand.
Lastly, If your pictures indoors are where you see grain the most, then the issue is the lighting. you need to add an external flash such as a Canon Speedlite 420EX. having too low a light condition will cause grainy pictures.
Canon 30D
Canon Rebel XT Silver
Canon EF 50mm f/1.4 USM
Canon EF-S 17-85mm IS USM (Hoya Pro1 UV & Lens Hood)
Canon 430EX Flash (Sto Fen Omni-Bounce)
2,359 views & 0 likes for this thread, 6 members have posted to it.
2527 guests, 97 members online
