5DMKII registration issue`s. How do I register my name as owner and use the Metedata to protect my pictures for online use.? Thanks.
Jun 17, 2009 17:50 | #1 5DMKII registration issue`s. How do I register my name as owner and use the Metedata to protect my pictures for online use.? Thanks. Nikon D810 Nikon 50F/1.4G - Nikon 70-200F/2.8II
LukeCern Senior Member 926 posts Joined Jan 2005 Location: Torquay, Devon, UK More info | Jun 17, 2009 17:58 | #2 drdiesel1 wrote in post #8128751 5DMKII registration issue`s. How do I register my name as owner and use the Metedata to protect my pictures for online use.? Thanks. If you mean "how do I add my personal details to the in-camera metadata?", you need to install the EOS utility from the CD and hook your camera to your PC with the lead supplied.. Switch on the camera, run the Utility and there is a facility to edit the owner detail. ______________
Jun 17, 2009 18:29 | #3 Luke Cern wrote in post #8128792 If you mean "how do I add my personal details to the in-camera metadata?", you need to install the EOS utility from the CD and hook your camera to your PC with the lead supplied.. Switch on the camera, run the Utility and there is a facility to edit the owner detail. Hope that helps.
| Latest registered member is griggt 1103 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
