Thread started 17 Jun 2009 (Wednesday) 20:19
430ez as strobe
heymeng
Jun 17, 2009 20:19 |  #1
ok i probably know the answer but just to check
I just ordered cybersyncs and currently have the 580exII. I know I can sync to the 580exII via cable. I am looking for another flash to use and the 540ez is going for really cheap nowadays. the question is if i buy a zebra thingy to sync the 540ez to the cybersync receiver it should work in manual flash right. I ask this because it seems like a no brainer to use as a cheap second strobe.
:oops:
other items for sale on POTN
5DMKII >> https://photography-on-the.net …/showthread.php​?t=1344210
85 1.8 >> https://photography-on-the.net …/showthread.php​?t=1342324
50 1.4 >>https://photography-on-the.net …/showthread.php​?t=1342333
B1600+Vagabond Mini >> https://photography-on-the.net …/showthread.php​?t=1343633
MT ­ Stringer
Jun 17, 2009 20:37 |  #2
??? Your title says 430EZ. Which flash are you asking about?
540EZ works great. I used two of them with Skyports.
430EZ does not have a way to defeat (turn off) the auto sleep function so a minute of inactivity will cause it to go to sleep and you have to push the test button to wake it up. It could be a real bummer if you have it any distance from the camera.
Hope this helps.
Mike
Example of 540EZ with flashzebra hot shoe adapter and Skyport receiver.
IMAGE: http://i226.photobucket.com/albums/dd265/mt_stringer/Basketball/FlashSetup-650.jpg
MaxPreps Profile (external link)
My Gear List
heymeng
Jun 17, 2009 20:39 |  #3
your right i was thinking 540ez. ill change the heading
thanks for the reply
746 views & 0 likes for this thread, 2 members have posted to it.
430ez as strobe
1634 guests, 171 members online
