I'm not sure if its a problem with my lens or just my focusing, but i can't get to get it right. I'm using a Tamron 70-200 f/2.8 Macro lens, and i can't seem to get a nice macro shot. Any suggestions?
Thank you.
dboghosian Senior Member More info | Jun 20, 2009 21:48 | #1 I'm not sure if its a problem with my lens or just my focusing, but i can't get to get it right. I'm using a Tamron 70-200 f/2.8 Macro lens, and i can't seem to get a nice macro shot. Any suggestions? https://droboghosian.viewbug.com/
Naturalist Adrift on a lonely vast sea 5,769 posts Likes: 1251 Joined May 2007 More info | Jun 20, 2009 21:53 | #2 Best advice I can give is to tighten down on the f-stop to increase your DOF. You've got a narrow DoF in this image, which seems to be properly focused in that portion of the shot.
i forgot to mention that i had to set the fstop to 5.6 to even get this shot. at 2.8 i was getting a darker image and not as clear of a shot. https://droboghosian.viewbug.com/
Jun 20, 2009 23:34 | #4 1. Are you using a flash? If so try f8 to f11
Jun 20, 2009 23:38 | #5 thank you alann for the info. i was not using a flash. it was today, and this snail was actually stuck under my car's tire, and removed it and put it up on a ledge. and decided to take a shot of it. i didn't use my flash for it, but next time i will. https://droboghosian.viewbug.com/
LordV Macro Photo-Lord of the Year 2006 More info | Jun 21, 2009 00:31 | #6 Nice one. The focus on the front part of the shell is pretty good. As Alan says above try using MF if you were using AF , even if the AF works it doesn't know what you ant to focus on and with the narrow DOF you get with macro, it's often the wrong bit. http://www.flickr.com/photos/lordv/
| Latest registered member is semonsters 1049 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
