Thread started 21 Jun 2009 (Sunday) 09:30
Photographing Swimming Pools
mattyb240
Jun 21, 2009 09:30 |  #1
Hi,
Yesterday I had my first go at photographing swimming pools for a friend of mine, I admit now my lens is not wide enough for the shots, but am just wondering how hard people find it to give it a good exposure due to reflections, over head lighting, natural light through windows.
I only had a quick five minute go, I tried taking exposure from outside, next to the pool on the copings, and an exposure in between. This is what I managed taking the exposure from a compensated exposure. Is there anyway to get it better without editing? Or is it a case of "dodging" the dark areas? Also I know this isn't the straightest but it was just a quick test to see what it would turn out like. The more I look at it would a fill flash help maybe bounced off the roof? I have no experience with flashes!
Thanks!
Deviant Art (external link)
TheFloridaShooter
Jun 21, 2009 09:39 |  #2
Did you use a tripod? If you shot this in RAW you have more options to edit in photoshop.
FujiFilm GFX 100 | FujiFilm GFX 100s | Fuji X-T4 | Sony Alpha 1 | Sony a7Rv | Sony a7Riva x2 | Sony a7Siii | Sony a7c | No Wife
CAL ­ Imagery
Jun 21, 2009 10:39 |  #3
Circular polarizing filter. Make it your friend to combat the glare from the pool.
Also, make friends with HDR - don't make it look like a painting - but use it to bring back ranges.
Christian
Tony-S
Jun 21, 2009 10:52 |  #4
Yeah, HDR is the way to go. If you have sunlight outside (windows) and dim inside, you're talking about 5-7 exposures around 1 stop apart. Meter the window light, then the darkest inside spot to gauge your exposure range.
"Raw" is not an acronym, abbreviation, nor a proper noun; thus, it should not be in capital letters.
SuzyView
Jun 21, 2009 10:53 |  #5
I'd go as far to the ground as possible to get the shot as well. That makes the room look bigger, too.
heycow
Jun 21, 2009 11:08 |  #6
Can you shoot by the corner to your left? That way the windows will be lighting the pool rather than messing up your metering. All depends on the background of the hidden wall, etc. Also, Can you shoot it more squared on? From either the long end or the side?
Also, consider shooting it on a clear moonlit night.
Hello, my name is BEN
Family Photos (external link) :: My Maya-A-Day (external link) :: One Owen-A-Day (external link)
Canon 40D :: Canon 24-105f/4L IS :: Canon 50f/1.4 :: Sigma 30f/1.4 :: Canon 580EXII w/Big FlipIt! :: Like a dozen different bags...Go Crumpler! :)
Tony-S
Jun 21, 2009 11:36 |  #7
There's also photostitching if you can't get wide enough.
mattyb240
Jun 21, 2009 11:54 as a reply to  @ Tony-S's post |  #8
Thanks for the suggestions,
heycow, I can't go to the left due to a sauna in the corner, and my lens is not wide enough to go straight on which is very unfortunate.
This was all used using a circle polariser but only some reflections were minimised, this was not a serious attempt in capturing the image for composition or the best look, it was mainly for experimentation of obtaining the correct exposure. I will definitely try a bracketed exposure and attempt a HDR which should be good!
Unfortunately it was shot at around 2pm in the afternoon, the next attempt I go for will hopefully be early morning or late evening for a better light. The reasoning behind me even attempting this is my friend spent £1000 on a 450D with two lens combo an leaves it in the magical green box setting so it doesn't look anywhere near as good. So I want to get experience myself on shooting pools (as he is a swimming pool builder) to try and show him a better way!
Thanks for the replies so far, its all food for thought!
DYORD
Jun 21, 2009 12:04 |  #9
i wonder how you got that well exposed (with details) and not over-exposing the outside. I'm still a newbie.. everytime i see these kinds of scenario, i knew i would blow the outdoor.
Canon 450D; Kit lens 18-55mm f3.5-5.6; 50mm f1.8, 55-250mm IS; 430EX II.
http://www.flickr.com/​photos/dyord/ (external link)
mattyb240
Jun 25, 2009 13:25 |  #10
I just thought I would update this thread, I tried a more serious attempt today with tripod in hand. Wasn't going for composition again but exposure, and did my first HDR using a total of 7 exposures ranging from the darkest in the room to the brightest.
Let me know what you think as I would be keen to hear opinions.
Tony-S
Jun 25, 2009 13:26 |  #11
A nice improvement. HDR is completely cool, eh? I'd get off-center a bit more, though.
mattyb240
Jun 25, 2009 13:38 |  #12
Thanks Tony, my only real complaint of it so far is that it doesn't appear that sharp? Although this image is compressed it just doesn't seem quite there but I can't put my finger on it? Also this was all done on a tripod with shutter release so in theory no movement should be there.
And thanks I will try a bit more off centre next time! Hell that could even be tomorrow!
Tony-S
Jun 25, 2009 13:58 |  #13
I use Photomatix Pro, which has an alignment tool. But since you're were on a tripod, it shouldn't matter. I assume you kept aperture constant and changed shutter speed. What was the slowest shutter speed you used and what was the ISO. Sometimes noise can cause an image to look less sharp. But from the image you have it doesn't look like much of an issue to me.
mattyb240
Jun 25, 2009 15:58 |  #14
Yeah was just a shutter speed change, I have just done the alignment tool which makes it look better, and the iso was 200.
egordon99
Jun 26, 2009 06:44 |  #15
Flash/off-camera lighting. You set your shutter speed/aperture/ISO so that the outside doesn't blow, and then you set your lights/flash to an appropriate power (based on ISO, f-stop) to illuminate the inside.
DYORD wrote in post #8148629 (external link)
6,948 views & 0 likes for this thread, 9 members have posted to it.
1461 guests, 143 members online
