Thread started 21 Jun 2009 (Sunday) 23:28
IR color cast
r.morales
Jun 21, 2009 23:28 |  #1
I just started playing with an XTI and a 760 nano filter . [EFS 17-55 - iso 400 - f 5.6 - EV 15 - started working at 1 minute , 1 1/2 and 2 .] I used a tripod and canon's intralval timer . Focus set at infinity .
It took a while to figure out I had to set on bulb . Manual with timer only work in bulb mode .
After shutter closes , it takes about a minute for camera to load picture to card .
I had a redish or pinkish cast to the shots .
Looking for answer to either remove or shoot so I don't get the color cast .
The batteries ran low . Add , subtract other filter , R-72 filter is coming .
Has anyone tried a cross screen with IR ?
The pictures are with the filter and without .
r.morales
Jun 21, 2009 23:34 |  #2
I just checked exif data is there . focus , camera shifted when I removed filter .
Yes it was a little windy .
Picture ­ North ­ Carolina
Gaaaaa! DOH!! Oops!
Jun 22, 2009 06:44 |  #3
r.morales wrote in post #8151417 (external link)
https://photography-on-the.net …php?p=8152499&p​ostcount=6
Website (external link) |
r.morales
Jun 22, 2009 09:30 |  #4
Thanks , I have seen IR shots that did not have the cast .
I am on a mac and have CS3 extended . I really have not played with it except for auto in raw and resizing to post on web .
I didn't know if I had camera set up wrong , cast is normal with IR filters , could maybe at a filter or what .
I did post this in 3 different spots , no area just for IR .
Thanks again .
bikerider
Joined Apr 2004
Jun 22, 2009 10:21 as a reply to  @ r.morales's post |  #5
The colour cast can be removed using channel swap in channel mixer in CS3, or by using an action, I use one by Khromagery but channel mixing is not difficult. I am shooting with a modded camera, sample below.
Alternatively just do a greyscale conversion and process as a normal b&w, again sample below.
Eos 6D Mk1, 300D & G7x modified for Infrared, 17-40f4L, 70-200f4L, 100-400 f5.6 ISL, 15mm f2.8, 50mm f1.4, various Lensbaby lenses, a few tripods, flash, GoPro 7 black.
r.morales
Jun 22, 2009 17:02 |  #6
What is a modded camera ?
Thanks for leaving exif on picture but didn't help much .
I'll go play with photoshop now .
r.morales
Jun 22, 2009 17:32 |  #7
Thanks , I played with it in photoshop . I tried channels , could not find channel mixer .
Curves changed a lot , but still not what I wanted .
I just saw I didn't change number - I always save to desktop and move or trash later .
bikerider
Joined Apr 2004
Jun 23, 2009 02:01 as a reply to  @ r.morales's post |  #8
have a read of this, it should help http://khromagery.com.​au/digital_ir.html (external link) :)
3,838 views & 0 likes for this thread, 3 members have posted to it.
IR color cast
1588 guests, 138 members online
