Thread started 23 Jun 2009 (Tuesday) 15:22
50mm 1.4 on Full Sensor and Crop (Can you post picture examples of both?)
SAB_Click
Jun 23, 2009 15:22 |  #1
I would be interested to see examples of the same picture taken with the Canon 50mm 1.4 ideally on both a 40D and 5DMKII and preferably wide open or near wide open. Other crop and full frame combinations will do if the two bodies mentioned are not available.
Basically what I am trying to understand what I would gain on my 40D by buying this lens immediately and what I would not get ahead of buying a 5DMKII.
Any other comments in addition to examples would also be appreciated.
dad3*3
Jun 23, 2009 15:27 |  #2
Plenty of comparisons available, just try Google, you will get more than you can stand. Here is a quick example;
http://www.flickr.com/​photos/nifmus/30791843​53/ (external link)
SAB_Click
Jun 23, 2009 16:19 |  #3
dad3*3 wrote in post #8161020 (external link)
Thanks. That example is not exactly what I was expecting.
What I am trying to understand is if you get better bokeh (or anything else?) on a full frame above a crop camera with this lens, as I presume more of the lens (glass) is contributing to the image? For example I understand that a TS lens will not give the full TS effect on a crop sensor because there "isn't enough image size for it to perform properly", or so I was told. I have taken this logic to thinking about a wide open prime with my above request.
tkbslc
Jun 23, 2009 16:23 |  #4
80mm 2.8 on APS-C is like 50mm 1.4 on a full frame in terms of framing and DOF. Your DOF will be about 2 stops thinner with similar framing. Of course a 50mm lens on full frame will be like a 30mm lens on APS-C fro feild of view. So it is hard to directly compare the lens on two bodies.
Taylor
EOS Rp | iPhone 11 Pro Max
SAB_Click
Jun 23, 2009 16:43 |  #5
tkbslc wrote in post #8161353 (external link)
I think you have answered it for me with the "2 stops thinner". This is what I was trying to get my head around.
I would still like to see what 2 stops looks like, starting at 1.4 - as I currently don't have a lens capable of creating this.
prinspaul
Jun 23, 2009 18:11 |  #6
mm yea but the FOV changes as well... so you should compare 50mm(crop) and 80mm(FF) with the same aperture to see the real difference...
Super-Nicko
Jun 23, 2009 19:31 |  #7
I cant locate any comparisons ive done with 50mm at the moment -
Would you want 50mm 1.4 40d
then 50 1.4 5d2 and walk closer to subject to frame them the same??
off hand i have this to compare going from 43mm 40d f2.8 to 70mm 5d f2.8
i know its not what your asking for... but its all I have sitting online atm. I stood in the same spot to take both pics
40d
IMAGE: http://i235.photobucket.com/albums/ee188/supernicko/40dweb.jpg
5d
IMAGE: http://i235.photobucket.com/albums/ee188/supernicko/5d2web.jpg
and this... again taken from the same distance but varying the FL to frame... The reasoning behind this test for me was if i had the 24-70 attached - and was standing in 1 spot and framed something to my liking - what is the difference in look when BOTH are at the same aperture.
This doesnt do exactly what you ask...i have millions of 50 1.4 shots on both cameras - just no tests of same framing where with the 5d i would have to step forward to change the framing - which would vary the background blur effect
top is 5d at 70mm f5.6, bottom is 40d 43mm at f5.6
IMAGE: http://i235.photobucket.com/albums/ee188/supernicko/40d5d.jpg
My gallery - just posted some of my top shots (external link)
1DmkIII / 5DMKII [50mm f1.4] [85mm f1.8] [100mm f2.8 MACRO] [17-40mm f/4L] [24-70mm f/2.8L USM] [24-105mm f/4L IS USM] [COLOR=black][COLOR=bl​ack][[COLOR=black]100-400mm f/4.5-f 5.6L IS USM] Canon 1.4xII - Speedlite 580EXII - EPSON P-5000 - Lowepro Bags - Manfrotto 682B Monopod & 055XproB Tripod - 488RC2
2,757 views & 0 likes for this thread, 5 members have posted to it.
1217 guests, 188 members online
