Let's see if I can explain, the question I have correctly.
I'm interested in experimenting with my strobes and a polarizer filter. I have read the manual of my Secokic 358 and it talks about setting it so you can have an idea of what a filter takes away in light so you can adjust the meter accordingly.
Now the difference is that in a polarizer you'll get 1 reading first and when you turn it you'll get another reading.
So my question is this. How would you recommend taking the reading? Taking various readings and see which is the part that the filter is at its "strongest"?
This would also help later when using strobes outside and using the polarizing filter to help underexpose the background.
