Thread started 26 Jun 2009 (Friday) 12:47
50mm f1.4 and 85mm f1.8 hoods
Rocktoe
Jun 26, 2009 12:47 |  #1
Both lenses use 58mm filters, could I use the 50mm f1.4's ES-71II hood with both lenses then? Would this cause any mysterious problems if it's doable?
Edit: If it would cause vignetting in the 85mm, could I vandalize the hood a bit to remove that? The reason I ask is I have an extra ES-71II in the camera bag and would like to use it for something.
Look behind you! A three-lensed camera!
450D | Sigma EF 530 DG ST Flash | Canon 50mm f1.4 | Canon 85mm f1.8 | Sigma 17-70mm f2.8-4.5 DC Macro | Canon 70-200 f2.8L |
silvrr
Gallery: 24 photos
Jun 26, 2009 12:51 |  #2
I dont think it would cause any vingetting as 50 is wider than 85mm.
Im not sure if it would mount though.
Canon 6D l 24-70 f/4L l 100L l 430EX l 430EX II l Kenko Extension Tubes l Sigma 50 Art
flickr (external link) FeedBack
Rocktoe
Jun 26, 2009 13:12 |  #3
silvrr wrote in post #8179680 (external link)
That's what I was thinking too, since I don't yet have the 85mm I haven't been able to check if it can be mounted or not. Maybe someone with both can pitch in and clear this?
krb
Jun 26, 2009 13:25 |  #4
Filter size has no direct relation to hood size. The numbers in hood model number tell you the size of the mount, 71mm for the 50 and 65mm for the 85.
-- Ken
Gear list
Rocktoe
Jun 26, 2009 13:29 |  #5
krb wrote in post #8179872 (external link)
Ah, ok... Thanks for the information, didn't know that. :D
msowsun
"approx 8mm"
Gallery: 18 photos
Jun 26, 2009 14:43 |  #6
Even if they were both 65mm or 71mm, they still would not fit because they use two entirely different ways of mounting the hood.
The 50mm 1.4 uses a twist-on bayonet mount.
The 85 1.8 uses a clip on mount.
Mike Sowsun / SL1 / 80D / EF-S 24mm STM / EF-S 10-18mm STM / EF-S 18-55mm STM / EF-S 15-85mm USM / EF-S 55-250mm STM / 5D3 / Samyang 14mm 2.8 / EF 40mm 2.8 STM / EF 50mm 1.8 STM / EF 100mm 2.0 USM / EF 100mm 2.8 USM Macro / EF 24-105mm IS / EF 70-200mm 2.8L IS Mk II / EF 100-400 II / EF 1.4x II
1,164 views & 0 likes for this thread
Latest registered member is ujpg
719 guests, 311 members online
