Thread started 27 Jun 2009 (Saturday) 12:46
550ex Wireless question
10range
Jun 27, 2009 12:46 |  #1
I am looking to add a couple more Canon flashes to my setup. My plan is to use my 550ex as the master and the additional units as a slave. My question; can I use the 550ex to fire the additional flashes without firing the one on the camera?
Gear list: Canon 20D, Canon 17-55IS, Sigma 70-200 F2.8, Canon EF 50/1.8, Speedlite 550EX
FreezeTheMoment
Jun 28, 2009 04:52 |  #2
I don't know enough to say for sure. But I heard you can shut off the flash but still use it as a master. Anyway, wouldn't the manual say something about this?
Gear list
A hobbyist here. I like taking pictures of people.
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Jun 28, 2009 04:58 |  #3
Yes, you can.
Cycle through the Sel/Set button presses until the Master Flash icon appears. Set Master Flash On or OFF using the + and - buttons.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
10range
Jun 28, 2009 07:56 as a reply to  @ CliveyBoy's post |  #4
Thanks for the info.
District_History_Fan
Jun 28, 2009 11:19 |  #5
CliveyBoy wrote in post #8188142 (external link)
Yes, you can.
Correct!
www.ericmcferrin.smugm​ug.com (external link)
apersson850
Gallery: 35 photos
Jun 28, 2009 12:16 as a reply to  @ District_History_Fan's post |  #6
There will still be a flash, to control the other slaves, but it will be of low power, and not affect exposure, unless the master is very close to the subject.
Anders
bobbyz
Jun 28, 2009 14:15 |  #7
apersson850 wrote in post #8189419 (external link)
Wouldn't the master/slave communication happen before the actual shot is taken?
Fuji XT-1, 18-55mm
CliveyBoy
Joined Nov 2005
Jun 28, 2009 18:23 |  #8
bobbyz wrote in post #8189879 (external link)
Yes and no!
What is loosely referred to as "preflash" covers several flash/camera events. After determining flash exposure levels and setting up master and slaves to deliver, the camera's shutter becomes fully open and there is a low-power coded flash telling the slaves to Fire. Obviously, this has to be when the shutter is open.
apersson850
Gallery: 35 photos
Jun 29, 2009 03:25 as a reply to  @ CliveyBoy's post |  #9
Yes, that's how it works. I wasn't sure if they (Canon) managed to send the trigger flash just before the event, to prevent the master flash from any impact at all, as far as the picture goes, so I did a test. By taking a photo, where the reflectors of both slaves and master was visible in a mirror, I could see that the master's flash was visible, regardless of whether it was set to "off" or "on". But it was significantly more powerful when set to "on".
Here's a quote from a user's manual on the subject of not using the master flash for illumination, but only for communication:
This operation will normally not affect the correct exposure of the subject, although the exposure might be affected if the subject is close and a high ISO sensitivity has been set. To limit this effect as much as possible, bounce the light by tilting or rotating the SB-900’s flash head.
If someone thinks it's inappropriate to quote a single paragraph from Nikon's SB-900 user's manual, then let me know or remove it yourself, if you can.
Anders
1,530 views & 0 likes for this thread, 6 members have posted to it.
847 guests, 142 members online
