taknbyd wrote in post #8188860
I'm trying to take close up pictures, let say a blade of grass with some drops of morning dew on it. But when I bring my camera close to the blade of grass, it doesn't have enough focus to bring the subject in focus. Is there a certain lens for this or something I'm missing? I've been photographing mainly human subjects for 6 months now. Any help would be great. Thanks.
Your question has essentially two parts and hence needs 2 answers.
First, as other have mentioned, you should be aware of your MFD of your lenses. The 50/1.4 has an MFD of 1.5ft. (0.45m). So, the lens can not focus closer than 18" away. That is NATIVELY.
You can always added "close-up" lenses such as others have suggested (which DOES degrade image quality), or you can use some Macro Extension Tubes to do the same thing (that is let you get closer) but without IQ degradation. Get yourself a full set of Macro Extension Tubes and start to explore.
Some people had mentioned that you should stop down, they didn't understand that you were attempting to focus at a distance closer than MFD. They said you should stop down. The reason nothing was in focus for you is that you were trying to focus at a distance closer than MFD. Stopping down would not have helped in your situation. But, once you do set yourself up to handle focusing closer (via Extension Tubes or Diopter Lenses (thats the technical name for "close-up" lenses)), you still need to control DOF via stopping down the aperature (f-stop).
Effective use of DOF is key to good Macro work. In general, the closer you get to your subject, the thinner the DOF. As you start to get magnification levels of 3:1 and higher, you will find that aperature of f/8 or less is remarkably useless, you will need f/11 and f/16 just to have any kind of usable shot.
The second question as far as special lenses you could consider a Macro lens, but your lens + Macro Tubes will offer similar results.
