Thread started 28 Jun 2009 (Sunday) 13:16
Gitzo Tripod choices
badams
Jun 28, 2009 13:16 |  #1
I'm looking for a tripod to hold my 500L with TC on a 40D. I was looking at the 3541XLS, but upon looking at the choices on B&H, I'm confused why one of these others wouldn't be better or at least a little cheaper.
I would prefer no center column. I will be mounting a gimbal type head (Bogen 3421 Head) on it. I'm about 6ft tall.
GT3530LS (external link) (This one is actually the same price as the 3541XLS)
GT3531LSV (external link)
GT3531S (external link)
Then finally the one I initially thought: GT3541XLS (external link)
Can someone explain the differences in these models to me or what would be the best for this setup?
I usually hand hold the setup, but after seeing some pics taken on a Gitzo tripod, I'm sold on getting a better one now.
My current tripod is a Amvona.com AT-828 with the Bogen 3421 head. I think it was only rated for 11 or 13 pounds so I'm pushing the limits of it and I'm sure thats why my pics aren't that sharp from the tripod. I'll post a pic yesterday taken with the setup so you can see an example.
Everyday use: 7D2, 1.4x v3 Canon TC (sometimes the 2x v2 Canon TC), Canon 500mm f4 L IS USM; 6D, 24-105L
http://www.southernokp​hotography.com (external link)
scot079
Jun 28, 2009 15:50 |  #2
I use the 3530LS w/ a Wimberley gimbal for the 500. I've never used any other tripod so can't offer a comparison. I'll just say it's a great set of legs that I couldn't do without
Edit: I'm 5'11'' and w/ the Wimberley I have to lower the legs about 2" to get the viewfinder right at eye level.
- Tim
www.timadkinsphoto.com (external link)
GEARandFEEDBACK
squiress
Jun 29, 2009 08:07 |  #3
The S signifies Systematic. So flat top, no center column. The V includes a bowl adaptor that replaces the plate:
http://www.bhphotovide​o.com …Q=*&bhs=t&Go.x=​24&Go.y=14 (external link)
The L (and XL) are length designations. You would need to measure from viewfinder to bottom of Wimberley mount and then tripod height to match to your eye height.
My Stuff
Thoughts-Tripods-Ballmounts-Teardown(TD)Benro KB2 Ballmount
TD Weifeng FT-565H Ballmount-TD Benro C128, C328n6 Tripods
TD Dynatran AT-A105T Tripod-TD Benro MC-68n Monopod
badams
Jun 29, 2009 09:51 |  #4
Ok so what are the differences between 3530 series and the 3541 series?
squiress
Jun 29, 2009 10:14 |  #5
A 30 means three leg segments; a 40 means four leg segments. Not sure what the 1 means at the end compared to the zero, but might mean G lock versus no G lock. You can go to specifications on B&H site and see what changes with a change in numbers. They should be consistent within a line, but as some have reported aren't always.
My Stuff
Todd ­ Lambert
I don't like titles
Jun 29, 2009 10:22 |  #6
I believe the 31 and 41 are newer than the 30 and 40 - that's it - no other major differences.
jhom
Jun 29, 2009 12:41 |  #7
The "1" designation refers to the version number. A 31 is newer than 30. The newer version has more leg angles and a lighter center casting, if I remember correctly. There may have been some other minor changes on the 2 series.
Jim
MDJAK
Jun 29, 2009 13:19 |  #8
I'm not understanding what that bowl adaptor does.
MDJAK
Jun 29, 2009 13:22 |  #9
I just read on the bh website it's for video heads. So for a RRS BH55 or a Markins 20, this bowl would not be useful, is that right?
I also have a Gitzo fluid video head, but it doesn't seem to need that bowl either.
badams
Jun 29, 2009 19:19 |  #10
Since I have a gimbal type head, do I need anything in addition to the legs? I see the Markins being mentioned, but cannot tell if I need something like that or not to attach my head or not.
squiress
Jun 29, 2009 20:53 |  #11
The gimbal mount is all that is needed. (And of course the plates that go with the mount to attach the lens to the gimbal mount). Some gimbal mounts (Sidekick) make use of a ball mount in the 90 degree position to hold the plate clamp. The Wimberley Classic or II don't need it.
My Stuff
jhom
Jun 30, 2009 00:09 |  #12
If you think it necessary for level horizons, particularly for panoramics, a leveling base would come in handy. Otherwise, a direct mount of the gimbal is all that is necessary.
Jim
badams
Jun 30, 2009 00:21 |  #13
Thanks everyone.
Jim, no I don't plan on doing many landscape shots so I'll pass on the leveling base. Mainly doing birds.
Now I just got to decide if I want to pay extra for the shipping to have it by this weekend or not.
edit: Got the 2 day shipping so hopefully I can use it this weekend.
3,248 views & 0 likes for this thread, 6 members have posted to it.
1050 guests, 104 members online
