I'll be vacationing in Ireland in two weeks and have a 18-55 and 55-250 for my T1i ... is there a must have lens that I need to take for inside shots or will these two do what I need?
Jun 28, 2009 19:03 | #1 I'll be vacationing in Ireland in two weeks and have a 18-55 and 55-250 for my T1i ... is there a must have lens that I need to take for inside shots or will these two do what I need? EF 50mm 1.8
RPCrowe Cream of the Crop More info | Jun 28, 2009 19:08 | #2 I would look into a fast lens that is relatively wide such as a 28mm f/1.8 or a 30mm f/1.4. Either that or get a flash and get used to using it creatively. Forget the built-in flash which gives "deer-in-the-headlights" look. See my images at http://rpcrowe.smugmug.com/
JohnHemlock Member 182 posts Joined Jun 2009 More info | Jun 28, 2009 20:27 | #3 I think those two will have everything you need. I am bringing a 35L but only because I am a lens whore, not out of necessity. Powershot A530, 2 AA Batteries, Wrist Strap
BigBlueDodge Goldmember 3,726 posts Joined May 2005 Location: Lonestar State More info | Jun 28, 2009 22:35 | #4 Hi Dwaine, for indoors I think you will want an UWA. Your 18-55 is not particularly wide, and I'm sure you'll find your self backing up to try and fit more into the picture. I used my Canon 10-22 mainly for inside shots. Some of those rooms in castles and such are pretty small, and you need wide to get them in. David (aka BigBlueDodge)
| Latest registered member is Monkeytoes 1370 guests, 180 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
