Thread started 02 Jul 2009 (Thursday) 08:36
DPP jpeg output not consistent
johnj2803
Jul 02, 2009 08:36 |  #1
hi, i have been shooting RAW and i have been using DPP to convert them to jpeg. The problem is after i increase some saturation and color tone (to my liking) when i convert them to jpeg, the adjustments are too much so the jpeg becomes too saturated.
is this really the case?
its just frustrating. thanks
My flickr (external link)
RDKirk
Adorama says I'm "packed."
Joined May 2004
Jul 02, 2009 09:06 |  #2
johnj2803 wrote in post #8211534 (external link)
What is your color management setup? Is your monitor calibrated? Are both DPP and whatever you're using to view the JPEGs matched to the same profile?
René ­ Damkot
Jul 02, 2009 11:11 |  #3
Jup. Likely a Color management issue.
Did you set the correct monitor profile in DPP?
(Prefs > Color Management. Set your monitor profile. Not sRGB for monitor profile. It's fine for working space, not for monitor)
IMAGE: http://www.moonglade.net/rene/POTN/color/DPP%20color.jpg
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
johnj2803
Jul 02, 2009 14:33 |  #4
mine is set to sRGB, both of them... since my camera is set to sRGB too...
are you saying that i should change it both to adobeRGB including the camera?
thanks for the replies :D
johnj2803
Jul 02, 2009 14:38 |  #5
RDKirk wrote in post #8211687 (external link)
how do i check if they are the same? I use a mac running tiger and iphoto for the jpegs (after conversion)
René ­ Damkot
Jul 02, 2009 14:47 |  #6
johnj2803 wrote in post #8213295 (external link)
No. Where it says "AdobeRGB" in my screenshot (work color space), it's fine to set sRGB. Good choice actually.
Where it says "Monitor profile" (for display) you absolutely should *not* choose sRGB. Set it to your display profile. If you use a newer version DPP on Windows, there's also a choice "Use OS settings" (or so) which should be fine as well.
johnj2803
Jul 02, 2009 14:51 |  #7
René Damkot wrote in post #8213374 (external link)
thanks :D i did just that :D will take tests and will update :D
thanks again :D
1,461 views & 0 likes for this thread, 3 members have posted to it.
1319 guests, 130 members online
