Thread started 02 Jul 2009 (Thursday) 20:49
ghosting from preflash?
aparis99
Jul 02, 2009 20:49 |  #1
I've noticed lately that some of my images, when using my 580exII, seem to have both the preflash, and the full flash, producing a bit of a ghost around the subjects.
Anyone know if this is normal or how i combat this?
My Site - www.apimagery.com (external link)
Canon R5 (x2), Canon RF 15-35 f/2.8L IS, Canon RF 24-70 f/2.8L, Canon RF 70-200 f/2.8L, Canon RF 100-500L, Sigma Art 35 f/1.4, Canon 85 f/1.8, Canon 100 f/2.8L Macro
Bearmann
Location: I live behind Graceland in a tool shed. I often meet the man early in the morning at Krispy Kreme.
Jul 02, 2009 22:34 |  #2
I don't think you can have the pre-flash in the photo because I don't think the shutter is open when the pre-flash occurs. Probably what you are seeing is a mix of flash plus ambient light.
Barry
http://b-r-s-photo.zenfolio.com (external link) (remove the dashes)
Joelene
Jul 02, 2009 22:39 |  #3
Are you on second curtain sync?
www.joelenemillsphotog​raphy.ca (external link)
This is a beautiful shot ..bw!
Miniflash
Titus213
Jul 02, 2009 23:36 |  #4
Can you post and example with exif?
I would suspect you are using Av and/or the shutter speed is too low.
Dave
Perspiring photographer.
Wilt
Jul 03, 2009 00:51 |  #5
Bearmann wrote in post #8215793 (external link)
^^ Right, the shutter is not open at the time of the preflash
CliveyBoy
R.I.P.      He will be missed
Joined Nov 2005
Jul 03, 2009 02:50 |  #6
Not during the main part of the preflash - the exposure testing and the slave flash setup - but does not the "Fire" instruction require that it is emitted by the master at the moment the shutter is open? I understand from Radiopopper's reading of the Canon patents that it does just that.
Clive, and Great G/D Abbie
50D; 580EXII, 430EXII, 550EX, YN685EX; YN-622C II, YN622C-TX and YN560-TX controllers TOYUG II v5.10 YN622 System Guide (external link)
I tried retiring, but gave it up - it's a dead end
Mark ­ Vuleta
Gallery: 48 photos
Jul 03, 2009 02:56 |  #7
Aren't the ETTL control signals IR & shouldn't be visible (or have so little effect in relation to the main flash output)?
How are things Clive?
DC ­ Fan
Jul 03, 2009 03:09 as a reply to  @ Mark Vuleta's post |  #8
Often, this comes from relatively bright ambient light and camera or subject movement when the standard 1/60 sync speed is used, not from pre-flash.
CliveyBoy
Joined Nov 2005
Jul 03, 2009 03:17 |  #9
Hi, Mark, and how are you? I miss meeting up with y'all.
An ST-E2 emits a "near-IR" signal, which can be a reason for using that device. However the 550EX, 580EX and 580EXII use the main flash tube, producing visible light. The power is low, but can have an effect in low-light conditions.
The effect is reproducable, if anyone wants to test it.
See post 9 in:
https://photography-on-the.net/forum/showthre​ad.php?t=715733
mmahoney
Jul 03, 2009 04:45 |  #10
I used to think that the pre-flash never showed up in exposures until someone suggested that it did, and said to prove it by setting up two 580's in a master / slave config with the master flash turned off, then take a pic of both in a mirror.
I've not tried it but this poster said they did, and that both flashes showed up in the exposure.
Newfoundland Wedding Photographer (external link)
apersson850
Obviously it's a good thing
Gallery: 35 photos
Jul 03, 2009 04:56 as a reply to  @ mmahoney's post |  #11
That "someone" was me. And yes, they both (master and slave) are on in such a picture. See the link above.
Should I post a sample picture?
On the other hand, the OP never stated that he uses Canon's wireless system. If his gear list in the signature is true to the letter, he has only one 580 EX II.
Anders
aparis99
Jul 03, 2009 07:42 |  #12
Hmm... I think its b/c i was at 200mm, using 1/60th of a second, and that's too slow for 200mm...
that's what it is im sure... thanks alot guys!
apersson850
Gallery: 35 photos
Jul 03, 2009 08:21 as a reply to  @ aparis99's post |  #13
If it matters or not depends on the strength of the ambient light, relative to the flash light.
Anders
vincent_su
Jul 03, 2009 11:15 |  #14
apersson850 wrote in post #8217381 (external link)
I agree and I have done the same. At slow shutter speed, with enough ambien light, the ghosting is caused by the camera shake or subject moving.
Dispite 1st or 2nd curtain sync, it will happen under the description above.
With a 200mm FL, a safe bet is to set TV mode at 1/200 or 1/250 shutter speed.
Vincent
"My dark room is bright and I like it."
5Diii; 24-105 f/4; 100 Macro f/2.8; 17-40 f/4; 70-200 f/4 IS; 100-400 II; TS-E90 and stuff.
apersson850
Gallery: 35 photos
Jul 03, 2009 15:59 as a reply to  @ vincent_su's post |  #15
The curtain you sync with is totally irrelevant in that case, for sure.
Anders
2,588 views & 0 likes for this thread, 11 members have posted to it.
1458 guests, 137 members online
