Thread started 04 Jul 2009 (Saturday) 00:01
Canon EF 300mm F/4 L Hood.
macroimage
Jul 04, 2009 00:01 |  #1
I recently bought a used Canon EF 300mm f/4L (not IS) lens. The hood slides back and forth but does not lock in the extended position. Is this normal for this lens or is there something missing that should keep the hood extended?
Photo Gear
dandig
Jul 04, 2009 00:43 |  #2
Hmm i'm not sure. I have the IS version and for that one you give the hood a quarter turn after you have extended it and that locks it. You tried that>?
DanCarrPhotography.com (external link)
ShutterMuse.com (external link)
My crazy gear guide! (external link)
macroimage
Jul 04, 2009 00:55 |  #3
The hood turns around and around smoothly. I notice that Photozone says that their copy is like mine. Maybe they are all like that.
Photo Gear
Gino17
Jul 04, 2009 00:55 |  #4
macroimage wrote in post #8220946 (external link)
I had a non IS version before, the built-in hood just slides back and forth without without any locking, this is normal. Don't have to worry about it.
macroimage
Jul 04, 2009 01:25 |  #5
Thanks Gino, that clarifies it. The lens seems to be excellent otherwise. The minimum focus distance is a bit long but nothing and extension tube won't fix.
Photo Gear
Saint728
Jul 04, 2009 05:22 |  #6
dandig wrote in post #8221120 (external link)
Cool, didn't know the lens hood locked. Just tried it and it does lock, only when you turn it to the right. :cool:
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
Saint728
Jul 04, 2009 05:28 |  #7
I didn't know Canon made a 300mm f/4.0L in non IS version?
Take Care,
Cheers, Patrick
ICee
Jul 04, 2009 07:47 |  #8
I have a non IS one and the lens hood won't lock either, think it must be ware, but the glass is still sharp.
Chez ­ Wimpy
Jul 04, 2009 09:16 |  #9
Non-IS here, mine still has "felt" or something causing resistance at the very end when it is extended.. it sorta sits in place. Never had it collapse on me unintentionally... and yes, this is a good lens (no experience with the IS version, but the non-IS is pretty much a clone of my 70-200/2.8IS image quality other than a slightly different WB cast)
-CW
生きのいい魂が手に余る
5D2 - 20D - 550D
Canon 24LII - 35
- 50II - 85 - 85L - 135L - 300/4 - 70-200/2.8IS - TSE 24L2 - 90
Sigma 15 - 30 - 50 - 12-24
gasrocks
Jul 04, 2009 09:19 |  #10
Put a rubber band around the lens just behind the hood when fully extended. Now, the hood will stay in place.
macroimage
Jul 04, 2009 12:24 |  #11
gasrocks wrote in post #8222156 (external link)
Excellent idea. I've been holding the lens with my left hand just behind the hood when taking pictures with the lens pointed up.
I was just concerned that maybe there was something wrong with the lens that the hood didn't lock like the newer ones do.
Photo Gear
promod
Jul 04, 2009 14:59 as a reply to  @ macroimage's post |  #12
thanks , I've had my 300f4 w/is for a year now and didn't know the hood locked . I used it just 3 or 4 times .. I must get it out more .. now that I don't work anymore , were going out more often , same with all the other glass .........
"if you are tired of starting over , then don't QUIT "
gcogger
Joined Mar 2003
Jul 04, 2009 15:01 |  #13
Well my non-IS version dos not lock either, but it's pretty old so I don't know if it's normal or faulty! Regardless, it's not a problem - I've never needed to hold the hood, even when pointing upwards, as it seems to stay in place well enough.
Graeme
My galleries (external link)
2,371 views & 0 likes for this thread, 9 members have posted to it.
489 guests, 122 members online
