Does anyone know what the largest CF card that a Canon G3 can use?
Intended use, to capture video for online posting.
Thanks.
JChin Senior Member 415 posts Likes: 1 Joined Jul 2004 Location: New York City More info | Jul 05, 2009 18:00 | #1 |
Jul 07, 2009 21:44 | #2 I've been using a 2g card, get 519 shots in P and 974 in Auto...and 999 shows up in the window for video...putting a 4g card in gives me 714 or so in P, 999 in Auto and again 999 in video mode...so I'd guess that 2g is the max the cam recognizes correctly. My Canon kit 450D/s90; Canon lenses 18-55 IS, 70-210/3.5-4.5....Nikon kit: D610; 28-105/3.5-4.5, 75-300/4.5-5.6 AF, 50/1.8D Nikkors, Tamron 80-210; MF Nikkors: 50/2K, 50/1.4 AI-S, 50/1.8 SeriesE, 60/2.8 Micro Nikkor (AF locked), 85mm/1.8K-AI, 105/2.5 AIS/P.C, 135/2.8K/Q.C, 180/2.8 ED, 200/4Q/AIS, 300/4.5H-AI, ++ Tamron 70-210/3.8-4, Vivitar/Kiron 28/2, ser.1 70-210/3.5, ser.1 28-90; Vivitar/Komine and Samyang 28/2.8; 35mm Nikon F/FM/FE2, Rebel 2K...HTC RE UWA camera
BobsYourUncle Goldmember 1,532 posts Joined Jan 2008 Location: Calgary Alberta Canada More info | I had a 4 gig in my G2 and it worked fine, so the G3 will do the same. Set Goals!! If you aim at nothing, you will hit it every time!
CyberDyneSystems Admin (type T-2000) More info | Jul 09, 2009 12:15 | #4 G3 may "work" with larger cards, but I believe it may be old enough to be limited to a FAT16 file system, in which case regardless of the card size installed, it can only use 2GB of it... GEAR LIST
| Latest registered member is semonsters 1472 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
