G'day Mark,
I don't want to scare you, but I recently had my 30D modded with the Baader UV/IR filter and was very disappointed. I haven't done extensive astro testing yet due to weather, but I use mine a fair bit for "normal"/terrestrial photography, and I've noticed what I thought were dust spots on my shots. At first I thought they were only going to be a problem on higher magnification macro shots, which
always do show up dust spots worse than normal photography. But I have also done some quick testing at typical apertures around f/8 to f/11. Spots. When I get a chance I'll do more significant testing and post images.
I contacted the guy who modded my camera (Eric) to ask him about how careful he was about dust etc. I have no reason not to trust him, I know many from our forum who have used him before. He reckons that he's contacted Baader about this, and they reckon the spots are actually in the filter as part of the fabrication process. Can't get rid of them. Here's an extract of their email to him:
Hi Eric,
thank you for your care.
Indeed every coating will exhibit such tiny specs which at not noticeable with fast optics .
At F22 the beam will become almost parallel and exhibit EVERYTHING - not just specs in the coating but every single grain of dust as well.
We are sorry but it is absolutely impossible to produce coatings without any of theses "specs".
We try to keep our coatings as immaculate as possible - we are sure you have seen "other" types of coatings from competitors of ours...
Best regards,
Johannes Baader
BAADER PLANETARIUM GMBH
My thinking is that if I was only using the camera for astro, I probably wouldn't care as much because the backgrounds are always dark which hides spots or makes them less noticeable, plus if you do flats they can be removed as well. But because I use it a lot for normal photography, I simply can't accept so many spots.
I've just bought (from Bobby/Strgzr27) a used modded 40D with the standard filter removed and clear glass only in front. He reckons no such spec/spot problems. I'll report back when I've received and done some testing.
Just letting you know my recent experiences.
