I am looking into buying a 300mm 2.8. I will be using it with a monopod and I need to know if you have to turn the IS off when using with monopod. If so I would like to just just buy a non IS lens.
britt777 Goldmember 1,148 posts Likes: 12 Joined Jan 2005 Location: Texas More info | Jul 07, 2009 19:25 | #1 I am looking into buying a 300mm 2.8. I will be using it with a monopod and I need to know if you have to turn the IS off when using with monopod. If so I would like to just just buy a non IS lens. Brittany
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Jul 07, 2009 19:44 | #2 No, you leave IS on when using a monopod and even on a tripod and IS will help. GEAR LIST
Cyclop Cream of the Crop 6,899 posts Joined Jun 2007 More info | Jul 07, 2009 20:54 | #3 In accordance to the manual, it is recommended to turn the lens image-stabilizer "off" when employing a tripod. However, when using a monopod, you can leave the image-stabilizer "on." Some IS lenses enable the user to change the IS mode manually to better accommodate shooting conditions. Canon 50D w/grip, Canon 7D, Mark II w/grip, Tokina UWA 11-16 2.8, Canon 17-55 2.8 IS, Canon 70-200 2.8 L IS, Canon 300 4 L IS, Canon 400 5.6 L, Canon 100 "macro" 2.8, Canon 60 "macro" 2.8, Canon Extender 1.4xII, Gitzo 3531S tripod w/Markins M20 ballhead, Gitzo GT2531EX tripod, Bogen-Manfrotto 681B monopod w/3232 head.
MinhThien Goldmember 1,644 posts Likes: 7 Joined Apr 2008 Location: Vancouver, British Columbia More info | Jul 07, 2009 20:56 | #4 britt777 wrote in post #8241863 I am looking into buying a 300mm 2.8. I will be using it with a monopod and I need to know if you have to turn the IS off when using with monopod. If so I would like to just just buy a non IS lens. Thanks Thats a good question! Someone should do a test on it! Eric
jcpoulin Goldmember 2,447 posts Likes: 13 Joined Jun 2006 Location: Massachusetts More info | Jul 07, 2009 21:01 | #5 It may be me...but I leave the IS off virtually all the time. In shooting sports, my shutter speeds are 800 and above..thus IS not much of a help. I also noticed that my focus accuracy and quickness increases when IS is off. Can anyone verify this? 1DX , 7D,16-35, 24-70 2.8II, 2.8L II, , 70-200 f2.8LII IS, 300 f2.8L IS, 500 f4 IS, 100-400L, Canon 100 2.8 macro, Canon 1.4X, 580ex, AB800X4
Jul 07, 2009 21:24 | #6 thanks so much for the tips. I couldn't get the manual for this lens on canon website so I thought I would ask here. My 500 says to turn IS off when using tripod, but wasn't sure for the 300. I don't want to invest in IS if its always turned off. Brittany
Sledhed Goldmember 2,510 posts Likes: 3 Joined Jun 2005 Location: Crete, IL. More info | Jul 07, 2009 21:29 | #7 You can only buy a new 300 with IS, they don't make a non IS version anymore. If you buy an older one beware that Canon may not service it anymore. I don't use the IS, don't need it for shooting sports. Chris
Sam|McGuire Senior Member 865 posts Joined Nov 2008 Location: Burlington, VT 05401 More info | Jul 07, 2009 21:39 | #8 Sledhed wrote in post #8242574 You can only buy a new 300 with IS, they don't make a non IS version anymore. If you buy an older one beware that Canon may not service it anymore. I don't use the IS, don't need it for shooting sports. You might want to go back and read the OP's post and the subsequent replys. Canon 5DII| 35L | 16-35LII |24-70L |70-200 F/2.8 IS LII | Alien Bees | CPS Member
Josh101 Senior Member 393 posts Joined May 2007 More info | Jul 08, 2009 01:27 | #9 on a monopod i always shoot with the IS on, on a tripod i will usually turn the stabilization off unless its windy, or whatever the tripod is resting on is unstable Gear List. | Joshua O'Neill Photography
dehoff Member 64 posts Joined Aug 2004 Location: Fargo, ND More info | Jul 08, 2009 12:37 | #10 Sam|McGuire wrote in post #8242624 You might want to go back and read the OP's post and the subsequent replys. ![]() Yeah, but it's a pretty valid point. One repair on a non-IS 300 2.8 and you probably could have purchased a used 300 2.8 IS in very good condition.
In2Photos Cream of the Crop 19,813 posts Likes: 6 Joined Dec 2005 Location: Near Charlotte, NC. More info | Jul 08, 2009 12:55 | #11 jcpoulin wrote in post #8242432 It may be me...but I leave the IS off virtually all the time. In shooting sports, my shutter speeds are 800 and above..thus IS not much of a help. I also noticed that my focus accuracy and quickness increases when IS is off. Can anyone verify this? IS/OS can take some time to "settle". If you are the type to press the focus button and then the shutter immediately after then leaving the IS/OS off is a good idea. However, if you are constantly tracking your subject and the IS/OS has already "settled" then it shouldn't matter. Using IS/OS with sports is nice if you are handholding as it can help keep your image stable with tracking your subject. When using a monopod I often have an image that is stable enough to track so IS/OS is not as much of a benefit. Mike, The Keeper of the Archive
Jul 08, 2009 21:39 | #12 |
Jul 08, 2009 21:44 | #13 When i'm using my 18-55 IS i turn the IS off on a tripod but on when handholding or my monopod is used the IS is on always . I move too much not to have it on .
Jul 09, 2009 10:08 | #14 I leave the IS on virtually all the time on my 300. I use a tripod or monopod for most of my shooting and have an extender on more often than not. Canon G1X II, 1D MKIV, 5DSR, 5DIV, 5D MKII, 16-35/2.8L II, 24-70/2.8L II, 70-200/2.8L IS II, IS, 100-400/4.5-5.6 L IS II, 500/4 L IS II, 24-105/4 IS, 50/2.5 macro, 1.4x MKII, 1.4X MKIII, 2X MKIII,580EX II, 550EXs(2), ST-E2.
sonnyc Cream of the Crop 5,175 posts Likes: 36 Joined Jun 2005 Location: san jose More info | Jul 09, 2009 10:28 | #15 I did, through a few soccer games
| Latest registered member is Marcsaa 641 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
