any ideas to improve this shot? thanks!
May 07, 2005 03:40 | #1 |
Vetteography Goldmember 2,032 posts Likes: 1 Joined Apr 2005 Location: Miami FL, USA More info | May 07, 2005 04:42 | #2 Black & White. The colors are pale anyway, and I think B&W would make this look even better.
Pekka El General Moderator More info | May 07, 2005 05:22 | #3 Composition draws the attention to the black square on the left. As the boy looks to the right, placing him left would have made him the true main subject and given more room for his thoughts. The Forum Boss, El General Moderator
Croasdail making stuff up More info | May 07, 2005 06:27 | #4 yeah I agree - unfortunately the metal wheel in the whole does draw attention from the boy without adding to the story. If the the background told more about the location, I would work to keep it but as it is now it could be anywhere from Singapore to Hongkong. Try cropping the image down and see if it still says what you intended. Or if it is critial to the story, perhaps just use PS to de-emphasize the wheel.
May 07, 2005 06:38 | #5 ok. thanks very much. ***********
Elbee19 Senior Member 732 posts Likes: 1 Joined May 2004 Location: San Bernardino, CA More info | Your fix really does make the photo come alive! He already has a great expression on his face. By placing him off center adds to that expression because viewers are now left thinking about what is causing that expression! Cheers,
| Latest registered member is semonsters 1599 guests, 141 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
