I'd like to see users' opinions and PICs of these 2 wonderfull 2 new Tilt Shift lenses !
roli_bark Senior Member 918 posts Joined Oct 2005 More info | Jul 09, 2009 04:44 | #1 I'd like to see users' opinions and PICs of these 2 wonderfull 2 new Tilt Shift lenses !
Jul 11, 2009 01:38 | #2 Bump ...
dandig Senior Member 346 posts Likes: 1 Joined May 2006 More info | Jul 11, 2009 01:46 | #3 check the lens sample archive....there are some in there
OiPaz Senior Member 704 posts Likes: 1 Joined Jul 2005 More info | Jul 13, 2009 03:02 | #4 roli_bark wrote in post #8261090 Nobody has these 2 wonderful new Beasties ? According to online tracking service my 17/4 will be delivered within the day! http://www.oipaz.net/
OiPaz Senior Member 704 posts Likes: 1 Joined Jul 2005 More info | IT is here! http://www.oipaz.net/
sheawyatt Goldmember 1,412 posts Likes: 30 Joined Dec 2005 Location: Victoria, BC More info | Jul 13, 2009 10:09 | #6 the-digital-picture.com has the ISO12233 Resolution tests for both lens published. Let's just say that the new 24 TS makes the mark1 look less than impressive. Unfortunately the high price and larger filter size means that an upgrade for me won't be happening. EOS R5 | RF 15-35 f/2.8 | RF 24-70 f/2.8 | RF 70-200 f/4 | EF 400 f/4 DO II | EF 1.4x III |
Jul 13, 2009 23:44 | #7 It also looks (from the same site) that the TS-E 24 MarkII is superior to the TS-E 17 for sharpness, both in center and edges.
OiPaz Senior Member 704 posts Likes: 1 Joined Jul 2005 More info | Jul 15, 2009 08:32 | #8 roli_bark wrote in post #8275982 the TS-E 17 for sharpness, both in center and edges. Yep, the 17/4 has to pay for its extreme focal length, and it's softer than the 24/3.5II especially in the corner wide open. But I usually shot with wide-angle TS-Es at f/8 or even f/11: at this aperture the 17/4 is evenly sharp and well contrasted troughout the picture. For instance, look at this 100% crop of the extreme corner with maximum shift (that's to say, 30 mm far from the optical axis of the lens!), no post production: to me it's impressive! http://www.oipaz.net/
Jul 15, 2009 08:49 | #9 Yes indeed, for a corner crop it is FANTASTIC.
timnosenzo Cream of the Crop 8,833 posts Likes: 14 Joined Sep 2005 Location: CT More info | Jul 15, 2009 15:47 | #10 B&H currently has the 24 TS-E II in stock.... connecticut wedding photographer
timnosenzo Cream of the Crop 8,833 posts Likes: 14 Joined Sep 2005 Location: CT More info | Jul 15, 2009 16:07 | #11 17 TS-E is back in too connecticut wedding photographer
timnosenzo Cream of the Crop 8,833 posts Likes: 14 Joined Sep 2005 Location: CT More info | Jul 15, 2009 16:19 | #12 timnosenzo wrote in post #8286373 17 TS-E is back in too http://www.bhphotovideo.com …Tilt_Shift_TS_E_17mm.html Scratch that, 17 is backordered again! connecticut wedding photographer
timnosenzo Cream of the Crop 8,833 posts Likes: 14 Joined Sep 2005 Location: CT More info | Jul 15, 2009 16:27 | #13 timnosenzo wrote in post #8286273 B&H currently has the 24 TS-E II in stock.... http://www.bhphotovideo.com …Tilt_Shift_TS_E_24mm.html
ChezWimpy Senior Member 430 posts Joined Jun 2008 Location: Hokkaido, Japan More info | sheawyatt wrote in post #8271788 Seriously? 12mm shift and almost NO loss of sharpness? AGGHHH! Based on the shift (compare this to the TS-E 17 samples) I am guessing the "center" of the image is now the extreme... which is why the "corner" doesn't get any visibly worse. Still, amazing performance, and I bought it on the samples seen to date. roli_bark wrote in post #8275982 It also looks (from the same site) that the TS-E 24 MarkII is superior to the TS-E 17 for sharpness, both in center and edges It should be. That 17mm lens is a lot closer to a "10mm FF lens" if you consider the whole image circle (hence the front element), and is compromised both in IQ and tilt-ability (only 6.5degrees in comparison with 8.5 on the 24) to manage its unprecedented FOV. Very exciting optics, both of them, and I hope to put the 24 to serious use in the future. -CW
sheawyatt Goldmember 1,412 posts Likes: 30 Joined Dec 2005 Location: Victoria, BC More info | Jul 16, 2009 00:38 | #15 Chez Wimpy wrote in post #8287895 Based on the shift (compare this to the TS-E 17 samples) I am guessing the "center" of the image is now the extreme... which is why the "corner" doesn't get any visibly worse. Still, amazing performance, and I bought it on the samples seen to date. Yeah, I know that. But the corner crops are now the ultra-extreme edges of the image circle, and even they show little-to-no loss of IQ!!. With the mkI things degrade rather quickly beyond the normal 35mm image circle. EOS R5 | RF 15-35 f/2.8 | RF 24-70 f/2.8 | RF 70-200 f/4 | EF 400 f/4 DO II | EF 1.4x III |
| Latest registered member is semonsters 1338 guests, 136 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
