Thread started 09 Jul 2009 (Thursday) 11:54
Pocketwizard - help with setup
krusnof
Jul 09, 2009 11:54 |  #1
Hi all,
I'm properly asking a stupid question, but need some help with a setup.
Currently I have a 40D (to be upgrade), 2x580, but sometimes I also use Bowens lamps.
For sync I currently use the ST-E2, but wants to make it more reliable with radio signals.
What would you recommend? I mean it's a pretty simple setup with max 2-3 lamps, so is there any need for the PlusII and MultiMax, or can I settle with MiniTT! and Flex TT5??
Please help me, as I have very limited knowledge in the functionality and needs when it comes to lighting...
Best regards
Kristian Kruse
40D + 50mm f/1.4 + 17-40mm f/4.0L + 430EX + Epson R1800
www.designforlife.dk (external link) + Flickr profile (external link)
jbergdoll
Jul 09, 2009 13:46 |  #2
Plus II will be fine since your lamps aren't ETTL compatible.
-Joseph
bergdollphoto.com (external link)
gear list
krusnof
Jul 10, 2009 03:35 |  #3
But can I then have Plus II for the lamps and then use the Mini/Felx for my camera and flash??
Best regards
Kristian Kruse
gromeo
Jul 10, 2009 08:07 |  #4
krusnof wrote in post #8255693 (external link)
I have used the mini with my Plus II and Multi Max and they worked fine, my problem was the distance, I was using it in a D1 basketball arena with the mini mounted on camera and multi max in the rafters, the mini would not fire the strobes from one end of the court, so I returned it. I should also mention that I use PW's for remote camera setups so it is easier with MM's PW II's
Nikon D4 and 60 2.8D Micro, 24-70 2.8G, 70-200 2.8G VRII, 200-400 VRII, SB800, SB600, Pocket Wizards, 4x WL-1600, Quantum Turbo 2x2, Sekonic 358 meter, TT AS, Takeoff, Belt System
http://rguzmanphoto.ph​otoshelter.com/ (external link)
http://www.romeoguzman​photography.com (external link)
http://www.sportsshoot​er.com/rguzman (external link)
913 views & 0 likes for this thread, 3 members have posted to it.
1081 guests, 177 members online
