Thread started 11 Jul 2009 (Saturday) 11:01
Help using my flashgun
penfolduk
Gallery: 12 photos
Jul 11, 2009 11:01 |  #1
Just got a 580EXII today and want to know how you use it to do a outdoor portrait pic and make the background look like it's nightime. Hope that makes sense and people know what I mean!
Phil
Fuji X-T3
Fuji 16-80mm F4
Viltrox 56mm F1.4
Wish list as long as your arm! and my arm! and my wife's arm! - you get the idea
Website (external link)
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Jul 11, 2009 11:46 |  #2
Find the correct exposure for the shot. Set it in manual & then dial it down about 5-6 stops. If that gives the background look that you want, then add the strobe & move it closer & closer until the "fill" is about right.
I'm moving this thread.
Curtis ­ N
Master Flasher
Jul 11, 2009 12:15 |  #3
Manual mode on the camera, E-TTL mode on the flash.
Set your shutter speed at 1/200 (the fastest shutter speed you can use without resorting to high speed sync).
Set your ISO at 100 and adjust the aperture for proper background exposure. Now close the aperture at least three stops from there. Example: You meter the background at f/8, then stop down to f/22.
Half-press the shutter button to activate the distance scale on the 580EX II. Note the maximum distance and stay within that range.
Shoot, chimp and adjust FEC as needed for the look you want.
Note: Max distance with the 580EX II zoomed to 105mm at f/22 is about 9 feet. You can use high speed sync with a faster shutter speed and a wider aperture, but your range will only be half as much.
penfolduk
Gallery: 12 photos
Jul 11, 2009 12:36 |  #4
Erm thanks for that, guess I just need to go practice that and try it lots and lots of times LOL
Doubt I will have it dialled for Mondays shoot tho
Cheers again guys!
Phil
Fuji X-T3
Fuji 16-80mm F4
Viltrox 56mm F1.4
PhotosGuy
Joined Feb 2004
Jul 12, 2009 09:36 |  #5
What? You should be able to set it up in less than 5 minutes the first time? Less than a minute the 2nd time.
penfolduk
Gallery: 12 photos
Jul 13, 2009 17:22 |  #6
Sorry guys couldn't sus it out, probably a dumb question but what's FEC?
Fuji X-T3
Fuji 16-80mm F4
Viltrox 56mm F1.4
SUB1IM388
Jul 13, 2009 19:09 as a reply to  @ penfolduk's post |  #7
FEC= Flash Expouser Compinsation. what the other POTN'ers were telling you is quite simple did you read your manual? After you do that you will know how to navigate around then follow there direction
Curtis ­ N
Master Flasher
Jul 13, 2009 20:19 |  #8
Flash is never simple.
Flash Exposure Compensation (FEC) is how you adjust the flash exposure in E-TTL mode.
penfolduk
Gallery: 12 photos
Jul 14, 2009 07:12 |  #9
SUB1IM388 wrote in post #8274653 (external link)
Yeah cheers for that, I need to download one as I got it 2nd hand from Jacons digital without one!
Anyone know where to get one?
Phil
Fuji X-T3
Fuji 16-80mm F4
Viltrox 56mm F1.4
dedsen
Jul 14, 2009 07:29 |  #10
Here is a link to a PDF manual. Good luck with your shoot.
http://www.eosdoc.com/​manuals/?q=580EXII* (external link)
penfolduk
Gallery: 12 photos
Jul 14, 2009 07:44 |  #11
Cheers for that Dedsen
Fuji X-T3
Fuji 16-80mm F4
Viltrox 56mm F1.4
1,825 views & 0 likes for this thread, 5 members have posted to it.
1306 guests, 135 members online
