Hi all,
I've been having troubles with my router for quite a while.
I have an older Linksys (maybe 3 years old) and I think it might be causing connection problems.
The router and connections are fine when downloading files, i.e. photos, movies, files, updates. But as soon as I need to upload something (small files to email, large files to flickr) the connection is lost and I need to reset the router.
I figure its the router as its the part I need to keep resetting. If the problem is the router is there a way to fix it? Do I need to upgrade? If so what should I be looking for? Is there a buffer of some sort that I should be looking at?
Hopefully someone can help.
Added info: I run mainly on a Macbook Pro, but I also have Dell laptop and a home built PC all of which have current software and firmware updates, and are all pretty powerful so they should be able to do these tasks without a problem.
Thanks in advance.
SInce I couldn't find a N router that matched the WRT54GL (WITH third party firmware, it is pretty crap stock) short of doing what I am doing....
