All the model numbers below are Novatron.
I have a D1000 power pack with 2103 FC heads rated at 1500 w/s each. Of course, I know you can use higher rated heads with a lower pack; but the other way around isn't allowed.
I have been offered two old Novatron heads, one 2020 and one 2010. I am curious if I have 3 2103FC heads plugged into the D1000 pack and one 2020 or 2010 head in the 4th outlet on the pack, are the 2020 and 2010 rated high enough to prevent any problems? I take it mixing heads is okay as long as they are all Novatron, but I would like confirmation on this as well.
Additionally, I read that someone had purchased an original Novatron kit with 2020s and 2010s and the pack that came with it was the 1600 pack, so I think that these lights must be at least 1000 w/s rated.
Any info would be most appreciated.
Thanks,
Pat
