Thunderbird33 wrote in post #8277341
Just a quick confirmation question if you don't mind:
The metering modes built into the body (spot, partial etc..) affect only the in-camera display when you are looking through it to compose the shot, and you adjust from there if desired or required.
But if shooting Av and TV, the metering modes affect the output of the photo aside from any exposure compensation you make from the initial meter reading?
The metering mode affects the exposure registered by the camera, regardless of whether you're shooting in manual mode or Av/Tv. The difference is in the way you adjust the exposure based on the result given by the particular metering mode you happen to be using. Assuming a constant ISO, with manual shooting mode you adjust either the shutter speed or aperture, or both, to get the exposure you want; with Av or Tv you adjust only the aperture or shutter speed, respectively, and the camera uses the metering information to adjust the other variable. There's no inherent relationship between the metering mode and the shooting mode.
