Thread started 14 Jul 2009 (Tuesday) 12:21
Ugh...DPP wont install on my netbook
40dbaby
Jul 14, 2009 12:21 |  #1
Didnt realize there was a minimum screen resulotion required. My netbook only goes up to 1024x600.
Only an untrained eye can appreciate the sharpness of a lens...
5DII | Zeiss 50 MP | Sigmalux | 85 1.8 | 24-70L | 70-200L II | 100-400L | 580ex II | 430ex II
FZ1
Jul 14, 2009 12:24 |  #2
Bummer, good to know. Netbooks generally lack the CPU & RAM to do serious photo editing anyway.
Joe
My equipment / Feedback / Info
René ­ Damkot
Jul 14, 2009 13:43 |  #3
Google is your friend:
http://www.ephotozine.​com/topic/t-71285 (external link)
A friend of mine got DPP to run on an even smaller screen with a workaround. Not sure exactly how, but IIRC he somehow set a higher screen res, then started DPP, then reset the screen res.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
hollis_f
Jul 14, 2009 14:15 |  #4
FZ1 wrote in post #8278776 (external link)
Agree 100%. Download Faststone. It's great for viewing images for culling of obvious duds. If you need to do raw processing then you really, really don't want to be doing it on a netbook.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
40dbaby
Jul 14, 2009 14:49 |  #5
I agree. But you cant beat the weight and portability of a netbook. I'm a noob and have been thinking about shooting in RAW lately.
To René Damkot, perhaps you can ask your friend how he/she achieved it. My netbook max res is 1024x600 and I've tried the method in your link, but no go. Also, I'd rather not have to hook up an external monitor to install/use DPP. Thanks again.
Amamba
Jul 14, 2009 23:14 |  #6
40dbaby wrote in post #8279635 (external link)
I have a netbook too and wouldn't attempt to do any serious editing in it, the screen just doesn't seem that easy to calibrate and is very reflective, so getting the right color would be very difficult. I use Picasa to get it "about right" & do any real editing on the desktop. I did load Paint.net on it for occasional more involved editing and it's working OK. Did you try a freeware RAW converter eg UFraw ?
You're right though, IMHO for most purposes the netbook beats the "regular" laptop as far as convenience goes; and they are not that sluggish either, definitely better / faster than my old laptop.
Ex-Canon shooter. Now Sony Nex.
Life Lessons: KISS. RTFM. Don't sweat the small stuff.
My Gear List (external link)
René ­ Damkot
Jul 15, 2009 08:44 |  #7
I asked & he had an EEE PC (Asus) with software which allowed him to boost the monitor resolution.
40dbaby
Jul 15, 2009 19:53 |  #8
Thanks to all. I have a samsung nc10 and it has software also to up the res larger then the screen and use the mouse to scroll the screen. I did not look too deeply into the matter from the beginning. Now DPP installs and runs fine for light editing:)
okh66
Joined Apr 2011
Apr 15, 2011 01:21 |  #9
just untick control panel->display->montor->advanc¬ed->monitor->hide modes or use external monitor
ChasP505
"brain damaged old guy"
Apr 15, 2011 10:01 as a reply to  @ okh66's post |  #10
My netbook runs Ubuntu Linux and comes with Gimp, plenty of other free viewing/editing software available.
Chas P
bohdank
Apr 15, 2011 16:15 |  #11
I use Faststone to view my RAW images in the field (or at least the imbedded JPG's). Works fine. I would not attempt nor need to do any editing when I am using my Netbook (travel).
DavidWatts
Gallery: 128 photos
Apr 16, 2011 02:01 |  #12
Running DPP 3.9.2 no problem on my ASUS netbook also. Native 1024 x 600 screen. A boost to 768 solved the installation issue. I won't actually edit on the tiny screen, but when hooked up to a 1900 x 1200 ViewSonic screen, it works fine.
My Smugmug site (external link)
Hen3Ry
Apr 17, 2011 10:20 |  #13
DavidWatts wrote in post #12232321 (external link)
I use a dell 10V. Canon software does require 1024x768 resolution, but it doesn't require that the main screen is that resolution. To install Canon utilities, plug another monitor into its video output and install.
Je n'avais pas besoin de cette hypothèse-là.
Virto
Joined Nov 2010
Apr 18, 2011 17:47 |  #14
If DPP only checks on install like EOS utility does, the fix is very simple and will take you only a few seconds.
Connect your netbook's VGA DSUB out to your desktop monitor. Even the crappy imbedded Intel video has enough oomph to push high resolutions on external displays.
Once you're using the external display, up the resolution to anything over 1024x768.
Install DPP and the rest of the Canon stuff as you see fit.
Disconnect the external display, reverting the netbook to it's own. My little HP uses a really odd native resolution, and even my eeePC has a slightly higher one.
Edit: lol, yhea I should read more carefully. Henry covered it for you.
Start DPP. If it's anything like EOS utility, it won't skip a beat. It should work fine from that point on.
Kelly - EOS 5D - EOS 40D - Rebel XS - EOS 10D - EOS 1D - SX230 - AE-1 - OM-1n - Minolta Himatic7 - EOS-1N
ABR800 - Several flashes, remote triggers, stands, too many and yet not enough lenses
3,876 views & 0 likes for this thread, 11 members have posted to it.
2844 guests, 166 members online
