Thread started 15 Jul 2009 (Wednesday) 00:14
50L Underexposing!!
jklewer
Jul 15, 2009 00:14 |  #1
I didn't even think it possible but my 50L is clearly underexposing by about 1 full stop no matter which camera it is mated to. I have used it and witnessed it on my 5D, 1D2N and a friends 5D2. Have any of you experienced this with any of your lenses? I am now part of CPS as of today so hopefully Canon can figure this out for me!! John
Gear
nicksan
Man I Like to Fart
Jul 15, 2009 00:16 |  #2
Nope.
But that may be a good thing(:D) since I find that the 50L looks better when you slightly underexpose and then bring it back up in post, especially wide open.
At least that's been my experience. I absolutely despised the way things looked wide open until I started doing this.
wimg
Jul 15, 2009 00:21 |  #3
jklewer wrote in post #8282481 (external link)
I haven't experienced this with any of the copies of the 50L I tested, neither on 40D, not on 5D and 5D II.
Are you sure this isn't some vignetting, or the selected metering mode?
The first copy I ever tried of the 24-70L had bad vignetting, same with the first 85 F/1.8, but never seen it since, other than any expected vignetting.
Kind regards, Wim
jklewer
Jul 15, 2009 00:49 |  #4
I just tested it a little (such a bad idea I know). Even at 1.4 it produces sharper, more natural colors. I am thrilled with this lens for what I bought it for... night vision. But im pretty sure it needs to go to canon for calibration...
Gear
nicksan
Man I Like to Fart
Jul 15, 2009 00:58 |  #5
I agree with Wim. This lens tends to vignette a lot depending on what you are shooting, perhaps giving the impression of underexposing.
But yeah, if you have any doubts, send it in.
Ob ­ Com
Jul 15, 2009 04:31 as a reply to  @ nicksan's post |  #6
My first 50L, apart from being hopeless at focusing, had a weird trait where by it seemed to produce very little exposure tolerance in camera.
Ie- any sort of shooting to the left, even only a fraction, would produce dramatic noise in camera.
I shoot to the left anyway so this was a problem.
My second copy has the same tolerance as my other shorter L primes- ie I can underexpose happily without noise.
Weird. I wonder wether it was a similar problem to the OP. Ie it was just underexposing?
"To look is to forget the name of the things you are seeing" Paul Valery
5D, 24-105L, 24L MkI, 35L, 50L, 85L MkI
Hermes
Jul 15, 2009 04:44 |  #7
This sounds a lot like vignetting to me. Very strong when the lens is wide open and can easily make things look underexposed if your subject isn't right n the middle of the frame.
muz64
Jul 15, 2009 08:42 |  #8
No problems with my 50L on my 5D2
1DX | 5D Mark II | 24-70 f2.8L II | 40mm STM | 50mm f1.2L | 85mm f1.8 | 135mm f2[COLOR=red]L[COLOR=b​lack] | 70-200 f2.8L IS II|
1,401 views & 0 likes for this thread, 6 members have posted to it.
50L Underexposing!!
Latest registered member is trempulant
865 guests, 112 members online
