Thread started 16 Jul 2009 (Thursday) 20:57
Electrice VS non
BigAlz1
Jul 16, 2009 20:57 |  #1
Hello all, I will have my 100MM 2.8 macro shortly and am already looking at some tubes to play around with. My question is how do the non electronic ex. tubes work? Obviously you will not have AF but how would you set the aperture? Would the lens just shoot wide open and have to be MF?
Was wanting to get a cheap set to play with but don't want to waist my money if I will not even get any use out of it.
Eos 7D, 40D w/70-200L 2.8 IS, 50mm 1.4, Nifty Fifty II, 100MM 2.8 Macro, 18-135mm IS , Sigma 30mm 1.4 , Sigma 18-35 1.8 ART 580ex II
LordV
Jul 17, 2009 01:24 |  #2
BigAlz1 wrote in post #8293606 (external link)
As you say loss of aperture control is the problem with non contact ext tubes. You have to preset the aperture you want with the lens attached normally, set the aperture in Av mode- press the DOF preview button and remove the lens whilst jkeeping the DOF button depressed. The lens will keep that aperture until it is next attached to the camera normally.
Of course the downside of this is a rather dim viewfinder. Personally I'd get the more expensive electronic contact versions either via EBAY or if you are in the US, you can get a Pro-optic set from Adorama fairly cheaply.
Brian v.
Macro Hints and tips
racketman
Gallery: 20 photos
Jul 17, 2009 02:09 |  #3
one thing about the over priced Canon tubes is that they do function properly - I can get AF and ETTL using the 60efs on a 1D.
Toby
Desertraptor
Gallery: 212 photos
Jul 17, 2009 03:05 |  #4
Kenko are a tad loose when attached but I don't think I have seen any real issue with them.
Peter
Canon 6D|60D|40D
Lens 10-22mm f2.8|50mm f 1.8|100mm f2.8 Macro
24-70mm f2.8|L100-400mm f4.5-5.6L
Flash 430EX II
Telescope Skywatcher 600mm ED80 f7.5 GEM EQ3
1,050 views & 0 likes for this thread, 4 members have posted to it.
Electrice VS non
1061 guests, 104 members online
