Thread started 19 Jul 2009 (Sunday) 02:11
DPP-why no lens correction for the 18-200mm?
purpletiger
Jul 19, 2009 02:11 |  #1
I have DPP v3.4.1 and can't use the 'Lens Abberation Correction' to correct vignetting, CA or distortion as the option is disabled. This only happens for my EFS 18-200. It works for the Tamron 17-50.
How can this be?
Also, dpreview specifically states that they used DPP for the 18-200 in their review. I think i have the latest version of DPP from here (external link) but i've read about a v3.5 which i cant seem to find the link to.
Light Is Everything
gcflora
"I'm not normal"
Jul 19, 2009 02:17 |  #2
Try googling for version 3.6.1
Cheers, Craig
Craig
http://www.australimag​e.com.au (external link)
purpletiger
Jul 19, 2009 06:44 as a reply to  @ gcflora's post |  #3
Thanks! Finally found information on it from this site. Canon Europe site's latest is v3.4.1! And its not exactly easy to find the latest version at Canon USA, its like Canon is trying to hide it from me! :rolleyes:
Light Is Everything
Lowner
"I'm the original idiot"
Jul 19, 2009 09:08 |  #4
purpletiger,
version 3.6.1 is available from Canon Europe. I downloaded mine in May. The problem seems to be that they offer ALL the versions leaving the user to do the weeding out.
Richard
purpletiger
Jul 20, 2009 15:01 |  #5
Lowner wrote in post #8306039 (external link)
purpletiger,
Thanks Lowner, my bad. Must check next time before falsely accusing! Still, Canon could make it a tad easier to get to the latest version of DPP cos googling 'DPP latest version' doesn't seem to work too good (for me anway).
If anyone is reading this, when you get to your camera model in the Download Library page, remember to select which OS you are using (XP, Mac, etc) and only then will the latest version of DPP magically appear on the list of downloads!
Light Is Everything
Lowner
Jul 20, 2009 15:35 |  #6
Glad you found it. But your Tamron 17-50 cannot really be recognised by the software? Maybe DPP is getting confused. If thats the case, I'd not assume that the corrections are correct.
Richard
purpletiger
Jul 27, 2009 08:17 |  #7
Lowner wrote in post #8313267 (external link)
Wow, i didnt know that. Where can i get a list of lenses that DPP does recognise?
Light Is Everything
arnie12
Well, I thought I wasn't going to be noticed
Jul 27, 2009 08:47 |  #8
purpletiger wrote in post #8350219 (external link)
It should be in the help somewhere. Non Canon lenses are definitely NOT supported. Use Lensfun for that ;).
http://www.modelmayhem​.com/1017634 (external link)
"Monsieur l'abbé, I detest what you write, but I would give my life to make it possible for you to continue to write." -- Voltaire
tzalman
Fatal attraction.
Jul 27, 2009 10:32 |  #9
arnie12 wrote in post #8350361 (external link)
They are not supported but sometimes they confuse the camera and it writes an incorrect notation in the Exif that causes DPP to open the Lens Correction panel. My Sigma 15-30 does that too.
Elie / אלי
arnie12
Jul 27, 2009 12:53 |  #10
tzalman wrote in post #8350819 (external link)
They don't confuse the camera (well perhaps, but not in the way you think they do ;). In the lens <-> communication protocol there seems to be an identifier that says which lens it is. Non Canon lenses reuse identifiers from corresponding (??) Canon lenses, thereby lying to the camera. And, apparently, DPP uses this identifier to determine if it has correction data for this lens or not.
So, if DPP thinks it has correction data for a certain a non Canon lens, then it will use correction data from some Canon lens A to correct data from non Canon lens B. As the needed corrections for lens B most likely ARE different from lens A, you will actually worsen your pictures.
tzalman
Fatal attraction.
Jul 27, 2009 16:48 |  #11
Yes, I should have said "mislead" rather than "confuse".
For my Sigma 15-30 Exiftool shows this field in the Maker's Notes:
LensType : Canon EF 17-35mm f/2.8L or Sigma Lens
Elie / אלי
4,575 views & 0 likes for this thread, 5 members have posted to it.
1689 guests, 174 members online
