Thread started 19 Jul 2009 (Sunday) 11:05
High ISO speed noise reduction: also RAW?
cfibanez
Jul 19, 2009 11:05 |  #1
This can be selected under C.Fn II -2. The manual of the 40D says: "Reduces the noise generated in the image. Although noise reduction is applied at all ISO speeds, it is particularly effective at high ISO speeds." Does this also apply to RAW images or only JPG? The manual does not say ... Thanks!
5D4 | 7D2 | 11-24/4.0 L | 16-35/2.8 L III | 24/1.4 L II | 24-105/4.0 L IS | 40/2.8 STM | 85/1.2 L II | 100/2.8 L macro IS | 70-200/2.8 L IS II | 100-400 L IS II | 400/4.0 DO L II | 580EXII | EF 1.4x III | Gitzo monopod GM2541 | Gitzo tripod GT2541 | Really Right Stuff ball head & plates | B+W & Singh-Ray filters
bsaber
I have no idea what's going on
Jul 19, 2009 12:07 |  #2
That's a good question and I remember reading somewhere that it only affects jpeg. I could be wrong though. I don't remember where I read it but I'm pretty sure it was on this forum.
mikeassk
Jul 19, 2009 12:10 |  #3
I am gonna say only jpeg.
Keep in mind that your camera does a poor job at noise reduction compared to your computer and simple software which has to see the photos anyway. (unless your big on that nifty print button)
Stuff
AdamLewis
Jul 19, 2009 12:30 as a reply to  @ mikeassk's post |  #4
I dont know what camera youve got but mine actually does a pretty acceptable job with High ISO NR.
To answer the OP, it wont effect a raw image but it will still reduce your buffer even if youre only shooting in raw
tzalman
Fatal attraction.
Jul 19, 2009 12:30 |  #5
Definitely only jpg....except that like other jpg only settings the metadata notation affects DPP's defaults, although this one can be cancelled in Preferences.
Elie / אלי
mikeassk
Jul 19, 2009 14:05 |  #6
AdamLewis wrote in post #8306681 (external link)
Compared to your computer and software?
Stuff
AdamLewis
Jul 19, 2009 14:25 |  #7
mikeassk wrote in post #8306990 (external link)
Yeah. The camera does a pretty good job. I guess it depends on your standards though. Im not one who is looking for glass-like images from 6400 ISO.. :p
Electrical
Jul 19, 2009 14:32 as a reply to  @ AdamLewis's post |  #8
only highlight tone priority changes the RAW image because it shoots at different ISOs. other than that, not even picture style etc influences the pure raw picture.
cfibanez
Jul 19, 2009 14:37 |  #9
Thanks to all for input. I asked because I had dedicated C1 to M + ISO extension + high ISO noise redcution, but now I can delete these and dedicate C1 to something else.
mikeassk
Jul 19, 2009 14:41 |  #10
AdamLewis wrote in post #8307072 (external link)
Point noted,
ISO 6400 is quite high.
I use a 1DIII and 20/40D and whenever i "have" to shoot that high I usually just lower my expectations. :D
Stuff
PIXmantra
Jul 19, 2009 21:40 |  #11
cfibanez wrote in post #8306399 (external link)
Your answers:
1. It is performed by DiGiCIII, and it is done during or past raw-to-rgb conversion, on board the cam.
2. It is stored as a metadata in exif, thus not being applied to RAW data.
3. IT WILL BE replicated, VERBATIM, by converting the .CR2 with Canon's ZB/RIT.
4. On-board noise-reduction is ideal for ISo800-1250 (on 40D) and up to ISO1600 on 1D3, because it takes out Chroma-channels noise, and leaves Luma pretty much intact. This means not good enough past ISo1250-1600.
5. On 1D3, once active, it will kill your buffering capacity for high-speed shooting, whether raw or .JPG.
Cheers,
PIX
Click here for FlexNR-Professional Noise Reduction for EOS 1D3
CPS Member/ 2x1DMKIII/ 70D/ Pentax MX
300mm f/2.8 L II IS/ 24mm f/1.4 L II/ 35mm f/2.0 IS/ 17-40 f/4 L/ 24-105 f/4 L IS / 70-200 f/4 L IS
270EX/ 580EX/ 580EX II/ ST-E2/ CP-E3
HP Z800 x2 XEON, x12 Core/ EIZO CG241W/ Viewsonic VP930b
cfibanez
Jul 22, 2009 04:48 |  #12
PIXmantra wrote in post #8309055 (external link)
Your answers:
Cheers,
PIX
Thanks for this PIX!
JAcosta
Jul 22, 2009 06:45 |  #13
mikeassk wrote in post #8307130 (external link)
Point noted,
6400 is my bread and butter. Shoot to the right and pull back in post. Looks like 1600 and amazes me everytime.
Like any of the photos Ive posted?flickr flickr flickr (external link)
^^^Click Here^^^
Chances are you'll see something else you like!
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Jul 22, 2009 07:25 |  #14
tzalman wrote in post #8306682 (external link)
Just to clarify, ALL metedata settings that can be applied to RAW can be overrided or altered during conversion, even in DPP.
CDS' HOT LINKS
Curtis ­ N
Master Flasher
Jul 22, 2009 22:32 |  #15
With my 1D Mk III at ISO 6400, switching C.Fn. II-2 to On reduces the displayed buffer from 22 down to 14, about a 36% reduction, even in RAW mode.
I'm perplexed by this, since it's not converting the shot to JPEG and therefore not reducing any noise. Why would activating this function in RAW mode reduce the buffer?
4,146 views & 0 likes for this thread, 12 members have posted to it.
1323 guests, 127 members online
