Thread started 22 Jul 2009 (Wednesday) 21:01
Mark III Battery problem-question
PaintballPhotography.com
Jul 22, 2009 21:01 |  #1
Every time I check my battery status in the Battery Info screen in my 1D Mark III keep getting the following message “Calibration is recommended when charging battery next time” It is the stock LP-E4 battery and I have two other batteries that do not show this message. I have calibrated this battery twice and I keep getting this message. Should I assume this battery is beginning to fail and should be replaced?
Gary
Gary Baum
www.paintballphotograp​hy.com (external link)
NPPL 2009 Photographer of the Year
NXL Media Liaison
SportsShooter Member
Palladium
Jul 22, 2009 21:04 |  #2
PaintballPhotography.c​om wrote in post #8327436 (external link)
Gary
Maybe your not doing the Calibration correctly
Jul 22, 2009 21:50 |  #3
Thanks but I have calibrated my other batteries without this problem
Gary Baum
NXL Media Liaison
Adama
Jul 23, 2009 01:05 |  #4
In my experience, 1D3 battery calibration can be finicky. I once calibrated it and it refused to go past 75% charge, still showing the "calibrate" message.
The battery may be on it's way out, but I'd try calibrating it a few more times anyways. If that fails, just use it like normal and throw it out if you notice you're not getting the longevity you get from a healthy battery. In the end, as Canon says, calibration is just so your 1D3 can continue to display the exact power left in the battery in the Batt. Info screen. I believe, though someone is welcome to correct me if I'm wrong, that the bars are still more or less accurate.
Sorry to be a broken record, but are you sure you're doing it correctly? I usually leave the battery for a long time and let it sit in the charger for a bit even after it's fully charged when calibrating, since I have had issues in the past with taking it out before calibration was finished.
1D Mark III - 70-200mm f/2.8 L IS - 24-70mm f/2.8 L - 50mm f/1.4 - 580EX II
http://www.alexpylyshy​n.com (external link)
bachscuttler
Joined Oct 2004
Jul 23, 2009 04:39 as a reply to  @ Adama's post |  #5
Might be worth mentioning that during a calibration routine, the charger first has to completely flatten the battery and from that point (around two hours) completely recharge it.
I would leave it calibrating overnight or even longer.
Mine is too new to have to calibrate yet, but my 1d3 arrived with a faulty battery so did quite a lot of reading on the subject!
[AFTERTHOUGHT] If you have successfully claibrated other batteries, you will be familiar with how long it takes.
How old or well used is the battery in question?
camerastageleft.com (external link) |1D MkIII x2 | 350D | 17-40L | 24-70L | Nifty Fifty | 70-200L f4 | 100-400L IS f4/5.6 | Yongnuo PT-04 radio trigger/receivers | Slik Pro 700DX Tripod | Speedlite 580EX Mk1 + MkII & 430EX MkII | Cotton Carrier Vest + ever growing mountain of strobist gear.
2,252 views & 0 likes for this thread, 4 members have posted to it.
1223 guests, 109 members online
