Thread started 23 Jul 2009 (Thursday) 01:31
Distance to target in focus not provided in EXIF: why?
cfibanez
Jul 23, 2009 01:31 |  #1
Why is the distance to target in focus NOT provided in the EXIF? Focal length, apperture, shutter speed, all go from lens to camera and make their way to the EXIF. Why not distance to target?
5D4 | 7D2 | 11-24/4.0 L | 16-35/2.8 L III | 24/1.4 L II | 24-105/4.0 L IS | 40/2.8 STM | 85/1.2 L II | 100/2.8 L macro IS | 70-200/2.8 L IS II | 100-400 L IS II | 400/4.0 DO L II | 580EXII | EF 1.4x III | Gitzo monopod GM2541 | Gitzo tripod GT2541 | Really Right Stuff ball head & plates | B+W & Singh-Ray filters
wickerprints
"Shooting blanks"
Jul 23, 2009 01:45 |  #2
I have been asking this same question for months. Still no satisfactory answer. I believe EF lenses do not report distance info to the body. But I could be wrong.
5DmkII :: EF 24-105/4L IS :: EF 85/1.8 :: EF 70-200/2.8L IS :: EF 100/2.8L IS macro (coming soon!)
gofer
Jul 23, 2009 01:51 |  #3
Probably because the camera has no way of knowing the distance to the target. It would be different if the camera calculated the distance to the target for focusing purposes but it doesn't. The scale on the lens (if it has one) does give an indication of the distance of the object to which it's been told to adjust focus to.
Steve.
KenjiS
"Holy crap its long!"
Gallery: 622 photos
Jul 23, 2009 02:01 |  #4
wickerprints wrote in post #8328659 (external link)
Some do, most all the newer ones do...
Deviantart (external link)
gofer
Jul 23, 2009 02:25 as a reply to  @ KenjiS's post |  #5
Yes, I'm sure I've read somewhere that although most lenses do report the focus distance to the camera, the current EOS bodies don't record it in the Exif simply because Canon's own software has no use for the information.
Steve.
Alexei ­ TND
Jul 23, 2009 05:48 |  #6
would be dead usefull in astrophotography :D
Distance to target: 84.5 light years xD
|My Flickr (external link)| EOS 5D, EOS 7D
Canon 70-200L 2.8 IS, 24-70L, 400 5.6L
Sigma 50 1.4, 12-24, 20 1.8
SpaceArt (external link)
cfibanez
Jul 23, 2009 06:22 |  #7
gofer wrote in post #8328673 (external link)
Neither has the camera a way to know the focal length...unless the lens reports it to her. When I change the focal length ring on the lens, the camera knows it and registers it. Why not the same happens when I change the focus ring?
zincozinco
-Followers of Fidget-
Jul 23, 2009 06:35 |  #8
this is where some noink will come in and say "theirs do" :)
Living the life, overexposing...
Web (external link), Blog (external link) Name: Mike, Maik, Micke or just zinco.
bohdank
Jul 23, 2009 06:42 |  #9
As Kenji said, many/most of the newer lenses do report distance to the camera and it is available somewhere in the EXIF. When using a flash in ETTL, that information is sent to the flash to use in calculating the flash exposure. How to get at it is another matter.
In DPP, if you go into lens aberation correction, there is a distance slider that matches the actual distance set when the image was taken depending if the lens reported it.
PS. I haven't used DPP in ages..... this appears to no longer work in that all my lenses show infinity whereas in previous versions of DPP it appeared to show, relative to the scale, the correct distance, at least with some of my lenses.
AdamLewis
Jul 23, 2009 06:46 |  #10
How about the real question...
Why does it matter?
bohdank
Jul 23, 2009 06:50 |  #11
So we don't see question such as... my 400mm is soft when taking pictures of objects 2 feet away :-)
zincozinco
Jul 23, 2009 06:50 |  #12
it doesnt does it.... unless you work for achitects - but then they should know....
Goshawk
Jul 23, 2009 07:00 |  #13
Could be interesting but not very useful and no I do not know why not. Will be more useful to have for external flash especially when used off camera.
1D Mk III - 100mm 2.8 Macro - 24-70mm 2.8L - 70-200mm 2.8L IS - 500mm 4.0L IS - 430EX, 580EX II, ST-E2, Stroboframe, Quantum Turbo (external link)
http://www.flickr.com/​photos/deonnaude/ (external link)http://www.flickr.com/​photos/deonnaude/ (external link)
canonloader
Gallery: 6 photos
Jul 23, 2009 07:11 |  #14
I don't think the technology is up to it. For something within 50 feet, maybe, there is a lot of lens travel, but once it get's out there, the lens only moves in micro adjustments to focus where there are hundreds or thousands of feet of difference, or as mentioned, light years.
Mitch- ____...^.^...____
cdifoto
Don't get pissy with me
Jul 23, 2009 07:17 |  #15
I can't really know exact distance to subject but it can and does know at what distance the lens focused. At the very least that should be in EXIF. The lens I used and its focal length setting is already there when the lens supports such information, so there's really no technological reason for the focus distance to not be reported under the same conditions.
2,660 views & 0 likes for this thread, 15 members have posted to it.
1320 guests, 126 members online
